04-04-2021, 02:19 PM | #1 |
72 K2500 Rear Axle Identification.
Hello, Need some help identifying what rear end this is... Looks like a HO52, but not sure the ratio. Its on my 72 K2500 Sierra. I have looked at the identification charts but i don't have any letters in front of the numbers so i am a bit confused. Any help or ideas would be great. Thanks.
04-04-2021, 05:10 PM | #2 |
Re: 72 K2500 Rear Axle Identification.
There’s a 3 letter code stamped on the top of the 3rd member. If it’s a 70 or older it will be 3 letters.
It’s either 4:10 of 4:57.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
04-04-2021, 06:24 PM | #3 |
All about them K’s
The engine it came with can help shed some light on it but is not a total guarantee. Small blocks had a standard ratio of 4:11 with the inline 6’s having 4:56 as standard I believe. I’m not sure what the GMC V6’s had for standard. That Might help get you in the ballpark at least.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
04-04-2021, 07:01 PM | #4 |
Its has a 350 in it. It must be 4:56 then cause it runs round 3200rpm-3500rpm doing 60MPH down the hwy. Thanks for the info will also check the top of the 3rd member.
04-04-2021, 09:41 PM | #5 |
Can you post a picture of the SPID (sheet pasted inside the glovebox door)?
What engine was it born with? Does your VIN start with TK"S" or "E" or "M"? All these things can help determine what your truck was born with and what it has now. Keep in mind that your speedo may be way off depending on tire size (use a GPS to determine your rpm at an actual GPS speed). If your truck was born a V8, as Tyler pointed out, your stock ratio would have been 4.10 (in other words, if you still have your SPID, and it has an "E" in the VIN (& 350 appears on your SPID), but NO rear ratio appears on your SPID - your truck was born with 4.10s). But since who knows WHAT someone may have swapped in over the last 49 years - with GPS speed, eng rpm at that speed, and tire diameter, we can tell you precisely what you have now. Look fwd to some pics! We like our K20s around here |
04-04-2021, 11:22 PM | #6 |
Unless removed by a PO, the Dana 44 should have a ratio tag under a cover bolt and will match the rear (unless some serious PO stupidity...)
04-05-2021, 09:16 AM | #7 | |
04-05-2021, 09:18 AM | #8 |
04-05-2021, 09:33 AM | #9 |
Here is where the rear axle info is stamped on the Eaton third member
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
04-05-2021, 01:06 PM | #10 |
All about them K’s
If it was a small block truck originally and no spid ratio call out, it was born with 4:11’s. Hard to tell what has been done thru the years but probably a reasonable bet it’s got 4:11’s.
04-05-2021, 01:33 PM | #11 |
My book shows 70 and newer the codes are 3 letters and 69 and older are 2 letters.
04-05-2021, 02:30 PM | #12 |
Carpe manana
It's an Eaton axle but just a clarifying question. Didn't GM use a D60 for K2500s rather than the Ho52 seen with K20s?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 04-05-2021 at 02:48 PM. Reason: added |
04-05-2021, 04:32 PM | #13 |
My 1972 K2500 has Dana 60 in the rear. Maybe HO52 is a Canadian thing eh?
1972 GMC K2500 Super Custom Matt |
04-05-2021, 05:38 PM | #14 |
I have two k20s both eaton a c20 and c30 d60 diffs
Stock 350 k20 trucks are usually 410 gears both mine have a lockers the other is a straight 6 4.57 gears |
04-05-2021, 06:36 PM | #15 |
04-05-2021, 10:25 PM | #16 |
You are correct Pete, I missed the GMC part. I don’t think I have ever seen an HO in a GMC before.
04-05-2021, 11:53 PM | #17 |
04-06-2021, 06:52 AM | #18 | |
04-06-2021, 07:10 AM | #19 | |
04-06-2021, 08:42 AM | #20 | |
Do you have a picture of your option sticker?
04-06-2021, 08:58 AM | #21 |
04-06-2021, 03:08 PM | #22 |
I haven't seen this mentioned yet but have you had the cover off recently? Easy enough to pull the cover, count the gear teeth and you'll have your ratio, a little inspection and fresh oil.
04-08-2021, 03:41 PM | #23 |
Thanks for all the help. Got the letters off the top of axle. RJH which points to 4:10 gears. Thanks for the tips.
