Old 04-05-2021, 03:21 PM   #1
saddletramp
72 C-20 Help
Sorry forgot my picture what am i missing on my Q-jet carb im not hearing the back 2 barrel's opening up when i mash the gas any help and pictures appreciate you guys Saddletramp
saddletramp is offline   Reply With Quote
Old 04-05-2021, 04:10 PM   #2
Wrenchbender Ret
Re: 72 C-20 Help
Your choke is partally closed. It must be fully open for the secondary throttle to open.
George
Wrenchbender Ret is offline   Reply With Quote
Old 04-05-2021, 04:18 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 72 C-20 Help
Try pushing the choke plate all the way open (engine off!). Then open the throttle and watch the linkage on the driver's side to see if the secondary shaft rotates. If not, it's possible that the choke link isn't releasing all the way. Also make sure that the fast idle cam drops all the way down when you are holding the choke open. That's the lever right next to the body of the carburetor, inside where the vacuum pull-off linkages are. Also, make sure that the choke pull-off works. The top linkage prevents the secondary air valve from opening with the choke closed. That is the top link that is attached to the choke pull-off.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 04-05-2021, 04:26 PM   #4
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Re: 72 C-20 Help
The left side of the photo is cutting what I am looking at but it looks like the vacuum coming off the passenger side of the cab is going into a "T" that is also connected to the manifold vacuum? That can't be right?
my understanding (which could be wrong) that goes to the charcoal canister that is next to the battery (assuming you have have 3 port fuel pump and EEC Tank).
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 04-05-2021, 05:52 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 72 C-20 Help
Yeah, I wasn't going to address that, just yet. It may be that the line just runs back that way because the air cleaner is laid back out of the picture?
~Steven
Simi Valley, CA
Old 04-05-2021, 06:24 PM   #6
mr.mud1
mr.mud1's Avatar
Re: 72 C-20 Help
yes sir,all good info,the secondaries won't open unless the choke if off,and you don't need the nut on the air cleaner stud way down at the top of the air horn.the wingnut on top holds it all together.the nut might get in the way of the secondary metering rod hanger lifting up and allowing fuel to flow to the secondaries.
mr.mud1 is offline   Reply With Quote
Old 04-05-2021, 07:10 PM   #7
BigBird05
Re: 72 C-20 Help
Your picture is not showing the left side of the carb. Have a helper press down on the gas pedal and take a picture to see if your throttle linkage is opening all the way.
BigBird05 is offline   Reply With Quote
