04-06-2021, 10:00 PM | #1 |
Thread sealant on vac fittings?
What are your thoughts on using thread sealant on vacuum fitting threads? I am plumbing my vac gauge into the rear of my Edelbrock carb. Brass fitting into aluminum carb body. Yes or no on thread sealant?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
04-07-2021, 12:20 AM | #2 |
20' Daredevil (Ret)
Re: Thread sealant on vac fittings?
I'm no expert but I would definitely use a thin coat of teflon paste on the threads and then wrap teflon tape over the paste. I picked that up from a plumber and it works well on water pipe fittings. Should work equally well on vacuum fittings, especially with dissimilar metals where galling can be an issue.
04-07-2021, 02:07 AM | #3 |
On any threads I want to make sure are sealed I use a thin coat of Permatex aviation gasket sealer.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
