12-21-2003, 06:01 PM | #1 |
i installed another wiring harness and have problems
ok, i finally got around to it and pulled the old one out and put the used one i bought in. headlights wouldnt work. dash wouldnt work--like all the lights stay on constant and fuel gauge doesnt work... i tried another dash i had same thing happened.... everything hooked right up. i replaced all the fuses with the ones from my old harness and my tail lights are on constantly......???????????????? after playing alittle my headlights come on but thats it. both turn signal lights and high beam indicator stay on on the dash. i have the ground on.... what could be the problem. also, the plug that goes on the heater controls isnt right one and doesnt have the other part that plugs on the heater behind the glovebox and doesnt have the wire that goes to blower motor???? on my old on it was part of the plug that went to heater controls... anybody know what could be wrong?
70 longbed 496/th400/Ford 9" |
12-21-2003, 06:16 PM | #2 |
O M G
COULD NOT EVEN TELL YOU WHERE TO BEGIN.... SOUNDS LIKE YOU GOT SOME WIRE'S CUT,SHORTED,BURNED somewhere under the dash.... i think i might start at the rear of the fuse box?????? better go buy a very good testing light.....it's going to be your BEST FRIEND MAY THE FORCE BE WITH YOU |
12-21-2003, 06:27 PM | #3 |
Inline 69
what yr harness did you get?,,,,i believe 68,and older "front parking" lights shut off when you pull light switch to turn on head lights,,,,
12-21-2003, 06:44 PM | #4 |
i dont know waht year harness.... my parking lights stay on when i turn on my headlights...
12-21-2003, 06:50 PM | #5 |
Inline 69
fuel gauge,,,,make sure your getting power to the actual gauge,,,,,if you pull the brown wire off the sending unit does the gauge go past full?,,,,,
12-21-2003, 08:55 PM | #6 |
December 21, 2012
Is your headlight switch good?
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
12-22-2003, 01:02 AM | #7 |
Wrong year harness.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
12-22-2003, 01:07 AM | #8 |
what was wrong with the first(original) harness?
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
12-22-2003, 04:03 AM | #9 |
the other harness was all chopped up. i may end up looking at it and fixing it. the whole dash doesnt work... the old dash did. i put new dash and new harness in at the same time but the old dash doesnt work. headlight switch works bc headlights come on. are harnesses very year specific? im not getting power to actual gauge... i did with old dash and harness though. its all hooked up. my sending unit is bad so it stays at empty all the time
12-22-2003, 04:08 AM | #10 |
im seeing that the harnesses are same for 69-72 though
12-22-2003, 04:18 AM | #11 |
bust out the sodering iron and the heat shrink tubing
12-22-2003, 04:34 AM | #12 |
ok
12-22-2003, 01:21 PM | #13 |
Did the replacement harness and dash come from the same vehicle?
The only thing that comes to mind is you might have a harness for idiot light dash instead of a guage panel dash? You might want to check out the pinout for two to make sure they are the same setup that plugs into your dash. Here is link to GMC Pauls that shows the different pinouts http://www.gmcpauls.com/Tech%20Tips1.htm
12-22-2003, 09:56 PM | #14 |
the old and new harness' connectors look the same to me... i think im gonna stick the old harness back in there
12-23-2003, 09:56 PM | #15 |
ttt
