Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
So got a new ACDelco Professional water pump and there are two holes I need to cap off, I have the brass plugs but what is the best/proper way to seal them from leaking?
A ton of Teflon tape? Pipe dope? Thanks - I don't want leaks! <searched for the answer, guess I am stupid and the only that doesn't know>
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Water Pump Plugs - Best Way to Seal Them?
I use teflon pipe compound, then wrap a couple layers of teflon tape over the compound. No leaks.
Mr. Cheyenne
Hmm teflon tape compound ... going to look that up. That I don’t have.
20' Daredevil (Ret)
Teflon pipe compound is just pipe dope made with teflon. Any hardware store will have it and teflon tape in the plumbing section.
Who Changed This?
![]() Join Date: Jan 2013
Any good sealant will do the trick; you don't need anything special. I've used #1 and #2 Permatex, blue and black RTV, Indian Head shellac, whatever I had on hand. If it were mine, though, I'd use plugs with a 3/8" square drive or hex that is inset. Don't need that big ugly head sticking out...
Mr. Cheyenne
Orileys didnt have any innies :-(
![]() Join Date: Oct 2009
I've always used just teflon tape and nothing else - never leaked. Amazon will have 3/8 drive pipe plugs to your door in 24 hrs, it's worth the wait (I agree w/Steveedee's note on the plugs)
Mr. Cheyenne
You guys are killing me.... ordered for both holes - Brass Pipe Fitting, Hex Drive Countersunk Plug. One is 1/4 and the other is 3/8.
I think I'll do a good wrap with Teflon Tape - I have tons of that stuff laying around.
![]() Join Date: Mar 2003
Snug them up but do not over tighten them, you can crack the pump housing when using teflon as a lubricant
Don't care if they come out again? Black or Blue silicone ...
Mr. Cheyenne
The Right Stuff Black sealed with innie plugs, primed and painted! Time to dry, then install!
Mr. Cheyenne
Installed - so far no leaks and no more squeaks!
