Old 04-08-2021, 03:01 PM   #1
61hawk
61hawk's Avatar
Firewall Pad Fasteners - Found a Substitute
Like others after struggling to try those worthless plastic fasteners that are sold with the firewall and not wanting to spend $3 each for the rubber version I went to Lowe's and found what I consider to be a perfect substitute in the blue specialty fastener bins and they are only 83 cents for a pack of two.
61hawk is offline   Reply With Quote
Old 04-08-2021, 03:39 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Firewall Pad Fasteners - Found a Substitute
Thank you 61hawk great info. Just in case someone wants a part number, they are Hillam brand #881199. 3/8 push in fasteners.
Old 04-08-2021, 08:11 PM   #3
slepysal
slepysal's Avatar
great tip!!! thanks
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-09-2021, 06:44 PM   #4
jayoldschool
Moderator
Lowes has lots of good auto fastener stuff in those hardware drawers. Yes, you can find it cheaper on Amazon/Ebay. But, when you need something as you work in the garage, and it's right around the corner...
jayoldschool is offline   Reply With Quote
Old 04-10-2021, 02:23 PM   #5
roll_the_dice
roll_the_dice's Avatar
Good find...I have a few I had to cut out to do some rewiring and haven't replaced them yet. Thanks!
roll_the_dice is offline   Reply With Quote
Old 04-11-2021, 09:19 AM   #6
bigmoe
bigmoe's Avatar
I used Hillman well nuts on the inside and stainless steel bolts and washers on the engine side, (an idea I got from someone on this forum). It's a two person job though.
bigmoe is offline   Reply With Quote
Old 04-13-2021, 12:43 PM   #7
doobiebro
doobiebro's Avatar
Do you know how many I will need? Want to get them now so later when I purchase the fire wall pad I already have available. Thanx.
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 04-13-2021, 02:12 PM   #8
kens65fb
I went to Lowes this morning, I bought out the last 5 packets (10) fasteners, that they had.
The total with tax $4.27
kens65fb is offline   Reply With Quote
Old 04-13-2021, 02:20 PM   #9
61hawk
61hawk's Avatar
My truck has factory air and only required 4-5, but I cut the firewall pad out around where the air conditioner box sits and I think I used 7. A full firewall pad probably has 8 holes, I think the LMC pad kit comes with 12 of the plastic, unusable fasteners. On factory A/C trucks they eliminated everything from the hump to the passenger kick panel.
Old 04-14-2021, 11:05 AM   #10
roll_the_dice
I just picked up 4 packages of them. I am missing a few and wanted to have extras for down the road. I think I spent $3.83..money well spent!
