12-21-2003, 07:15 PM | #1 |
4 wheel drive
help..........i can't get my 4 wheel to work. It locks in on passenger side so i can't move the half shaft while its in neutral but when i unlock it it moves freely so i know the passenger side is locking in. The driver's side half shaft moves freely whether locked in or not as well as the front drive shaft. The transfer case is working so it seems cause when i put it in 4-lo i am limited to the speed i can go. Any ideas to what the problem may be?
12-21-2003, 08:04 PM | #2 |
If you are describing locking and unlocking your hubs, it sounds like the lockout is not pushing the engagement ring far enough into the hub to engage the axle shaft with the splines in the hub itself. But again, I don't totally understand what you are asking.
1957 Cameo |
12-21-2003, 08:20 PM | #3 | |
Bloo
sounds to me like only one of your locking hubs are locking, go ahead and replace both of them. if only one hub will lock, DO NOT put it in 4-wheel drive
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
12-23-2003, 01:01 AM | #4 |
yeah only one will lock in but i just replaced them two years ago they go bad that quick?
12-23-2003, 01:08 AM | #5 |
Seeker of the big and bad
If you dont use them alot they can get gumed up.I would at least take them apart and clean them.Depending on what your doing you can waste a set of hubs in a day. Buy locking them in your only leting the spring push them in.If it crusty,they won't ingage fully.
71 3/4 ton 4x4,665hp 454. 67 GMC 1 ton towtruck 68 chevy LB 4x4 64 chevy LB custom 57 Bel-air 2d station wagon |
12-23-2003, 01:18 AM | #6 |
if after cleaning and no sucess what brand should i put back on?
12-23-2003, 03:10 AM | #7 |
if cleaning didnt work, i would go with the upper-end warn hubs (supreme maybe? the exact name escapes me). they are the more expensive, but better, of the two kinds they make.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
