Old 04-09-2021, 01:02 PM   #1
Driver_WT
Driver_WT's Avatar
Adhesive for Window Felts
Getting my 1950 Chevy truck doors put together. Looking for a recommendation for the best adhesive to use on window felts.
Thanks.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 04-09-2021, 01:19 PM   #2
youngrodder
youngrodder's Avatar
Re: Adhesive for Window Felts
Thanks.
Wade
If you are referring to the felts (that were stapled on from the factory) that attached to the door window trim I used 3M double sided tape. The same stuff car moldings and emblems are held on with. It works great
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-09-2021, 01:32 PM   #3
Driver_WT
Driver_WT's Avatar
It is the channel that the glass window runs in (felts might not be the right word). Looks like it is called "upper run channel" https://www.classicindustries.com/pr...eyword&search=
It is the part that is about 8' long
Old 04-09-2021, 02:20 PM   #4
youngrodder
OK, Window channel. I didn't use any glue. You could use weather strip adhesive but it is messy. I just used (2) small screws in the upper corners of the window opening to secure it. Once the glass is in it that also helps hold it in place.
Thank you
Marc
Old 04-09-2021, 08:12 PM   #5
Driver_WT
Driver_WT's Avatar
Thank you
Marc
Thanks. I may try using a couple of small screws in the corners.
Old 04-11-2021, 05:15 AM   #6
MiraclePieCo
MiraclePieCo's Avatar
On my pickup I used Permatex Ultra Black silicone, and on my panel truck I used screws; both methods worked perfectly fine. Silicone had the advantage of holding the entire length of the channel, but the disadvantage of being messy. Some ADs I have disassembled had tiny screws in the upper corners of the window channels, but I don't know if those were factory original or not. If you do use screws, be sure to use flat heads and sink them in fully or they may damage the upper part of your glass.
This was my pickup with Ultra Black:
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 04-11-2021, 06:45 AM   #7
Driver_WT
Driver_WT's Avatar
Thanks MiraclePie.
Old 04-11-2021, 11:41 AM   #8
MARTINSR
MARTINSR's Avatar
Thank you
Marc
Yep, that is the best way for sure.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
