Old 04-11-2021, 05:00 PM   #1
geasson
Is it my fuel pump
My 1966 GMC 1-ton has been sitting way too long and so today I went to work on it. It has a new tank, good gas in the tank but it is NOT getting gas to the carb. When I disconnect the line from the carb and just crank, I get no gas. BUT when I removed the pump and operated it by hand, it squirted gas with no problem Do these V-6s have a rod that pushes the pump, or do they directly touch the cam shaft?
Should I just go with an electric pump??
geasson is offline   Reply With Quote
Old 04-12-2021, 08:59 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Is it my fuel pump
Cam. See post #10
http://67-72chevytrucks.com/vboard/s...d.php?t=481258
