New plastic float or replace the whole fuel sending unit
Pretty sure my float on my sending unit is shot. Rests at 1/4 and goes to full but doesn’t seem to read well.
I’ve been reading that newer units have faulty brass floats. Where can I buy a plastic float that will work with the original unit? Name, part number...? If the original unit is shot when I take it out, is there a replacement brand you all suggest? Posted via Mobile Device |
![]() Join Date: May 2010
Re: New plastic float or replace the whole fuel sending unit
Jim |
![]() Join Date: Feb 2002
Try the float first. Much cheaper. Then if the whole sending unit is shot, try one from GMC Paul. He's a member here, owns a truck like ours, and only sells what works best. His prices are competitive.
Perfect, will do. Thank you!
i replaced the holey brass float with a plastic equivalent and replaced the sock too. No trouble since
350/th350 DNA (Chinesium) Heads Performer Intake 1905 AVS2 Edelbrock 3.42 Eaton Posi |
Got a plastic float at my local O'Reillys this past summer.
Omix-ADA Omix-ADA Fuel Level Float OUT 1772901 |
