Old 04-13-2021, 11:45 AM   #1
prateroad
1970 C30 C&C weight
Well, it's been a while since I've been on here. I have a 1970 C30 cab and chassis that I need to ship from Colorado to central Florida. It has no engine or tranny. I need a good guesstimate on the weight for the shipper. All responses appreciated, I need to get'er done. I'd also like to know if anyone knows a good reasonable shipper. It's about 1800 miles. I have used uship before but sometimes you can catch a ride with an open slot. The truck is 20 feet long 6'6" wide without the side mirrors mounted.
prateroad is offline   Reply With Quote
Old 04-13-2021, 08:52 PM   #2
kwmech
Re: 1970 C30 C&C weight
What kind of wheel base does this have? GVW? No engine or trans I would guess between 4-5k
Old 04-13-2021, 09:21 PM   #3
Carl Spangler
Carl Spangler's Avatar
A 1970 C30 rolling chassis with cab and NO drivetrain, NO front end sheet metal, and NO bed should weigh under 3000 pounds.
1971 SWB step side: Original NM Forestry truck, then NM Fire truck, and now a ranch truck.
Carl Spangler is offline   Reply With Quote
Old 04-13-2021, 09:49 PM   #4
prateroad
I'm pretty sure it has an Eaton on the rear. It was a camper conversion. I don't know the wheelbase but from the pics it appears to be a couple feet longer than a regular flatbed dually. The front clip is on it. I think I'll look up the weights on the engines and tranny's and subtract. I don't know the GVW, I'll see if he'll send me a pic of the spid tomorrow. I think the GVW's in the spid numbers.
Old 04-13-2021, 11:17 PM   #5
68bowtie
68bowtie's Avatar
From memory (not super reliable)... my 152” wb c&c was about 4,200# at the scales. Without the drivetrain I can see it getting close to 3k.
68bowtie is online now   Reply With Quote
Old 04-13-2021, 11:25 PM   #6
kwmech
Wheel bases avail 127''---133''---157''
My 69 what once was a 'class B' motor home is 157'' wheel base. Had an HO72 in it
Old 04-13-2021, 11:27 PM   #7
prateroad
I found it at oldride library. They cover them all except V8's. Mine's the 2nd one down. 1 Ton - Model C - Series 30 - 133 in wheelbase
CS31002 - Chassis & Cowl - - 138
CS31003 - Chassis & Cab $2,735 3,641 lbs 14,873
CS31034 - Fleetside 8.5 ft. $2,935 4,157 lbs 1,404
CS31004 - Step-Side 8.5 ft. $2,875 4,071 lbs 2,101
Old 04-14-2021, 03:02 PM   #8
prateroad
Well , I just found out it's a 157" wheelbase.
