Old 04-13-2021, 07:24 PM   #1
mi396ss
Fuel Gauge Help
I installed a blazer tank under the box of my 1969 k20 with a new sending unit. I ran a new wire from the fuse panel to sending unit and grounded the sending unit to the frame. The tank is completely empty and the gauge shows 1/4 tank. When I remove the sending unit wire from the fuse panel, the gauge goes to 3:00. When I put a good ground on the fuse panel tab it goes to empty. When I connect the sending wire back up it goes to 1/4 tank. Any body have and suggestions on what’s going on? Thanks
mi396ss is offline   Reply With Quote
Old 04-13-2021, 07:30 PM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Fuel Gauge Help
GM tanks are 0-90 Ohm resistance. When you ground the wire for the tank unit, the gauge should read empty. At 90 ohms, the gauge will read full. Disconnected, that is infinite resistance, so the gauge should max out past full. I would test the tank unit to verify resistance values.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 04-13-2021, 08:08 PM   #3
mi396ss
So here’s what I found my problem to be. The way that the sending unit is “clocked” to lock into the tank caused it to hit a tank baffle ever so slightly so it won’t go all the way to the bottom. Do I need a different sender?
Old 04-13-2021, 09:24 PM   #4
mi396ss
I bent the arm enough that it’s reading pretty close to full.
