Old 04-14-2021, 09:51 AM   #1
Chevy527
Looking for Some Advice
I just picked up a 1968 K10 Stepside. I am contemplating doing over my bed with wood but after reading on this forum and the web it seems for my circumstances it might not be worth it.
The truck would be outside from May through September every year in NY about a mile from the Atlantic Ocean. I would store it inside for the winter. Since it's exposed to the Sun and elements all summer it seems like it might not be the right choice to completely do it over and then have to touch it up every year. I don't want to do annual maintenance on the bed.
Can i do it over with some type of stain/finish that would allow me to keep it outside and not have to worry about it or is it not worth it to do it over?
Chevy527 is offline   Reply With Quote
Old 04-14-2021, 10:05 AM   #2
sick472
sick472's Avatar
Re: Looking for Some Advice
Here is a thread that talks about using oil to preseve the wood, but it does take a minor amount of yearly maintenance...
http://67-72chevytrucks.com/vboard/s...d.php?t=712931
I have used a Penofin oil seal on my wood bed and will retreat yearly with some type of oil to make it a fast and easy task. The Penofin that I used as a heavy grey coloring and is cumbersome to keep off the brightworks, but a plain oil would be wipe-on/wipe-off.
I think Jeff's approach in the above link would be the least amount of yearly effort, aside from painting it. Paint would be a good way to go...just not a clear coat. That stuff tends to yellow and/or peal.
Do a web search on "mar-k bed wood test" and there is ALOT of reading on what works well and what does not.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 04-14-2021, 10:32 AM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The 67-72 wood beds were painted the same color as the body of the truck from the factory. Most held up pretty well after 40 to 50 years. No reason not to repeat that.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-14-2021, 10:35 AM   #4
Willys_MB
Willys_MB's Avatar
It depends on your feelings about the truck. If you're fine with wiping on a sealer annually, it shouldn't be a problem, but you said you don't want to do that.
The maintenance is the most important part. Keep it clean and keep it sealed. There is no way to keep wood sealed permanently without maintenance. It only takes 30 minutes to wipe on a sealer, including the time to tape up the edges. I do this on my utility trailer every year and it's not a big deal.
Depending on your drive and capabilities, you could use a synthetic decking material. I think people here have tried it before. It's not easy, but you wouldn't have to do maintenance.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 04-14-2021, 10:42 AM   #5
Chevy527
Yes, I saw a video on YouTube about using composite wood. Definitely wouldn't need any maintenance but doesn't compare to the real wood.
Old 04-14-2021, 04:32 PM   #6
67C10Step
67C10Step's Avatar
While I was picking up my new bed box at Mar K I spoke with a guy there, I think his name was David, and he took me into the offices and showed me packaging for a new product they will be marketing soon. It will be their own topcoat for treating wood beds. He said it has taken them about ten years to settle on something for them to sell. I am hoping they release it by the time I make up my mind what direction I am going.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
