12-21-2003, 08:51 PM | #1 |
lopsided stance?
I noticed after I replaced the springs and supports that my truck seemed to be a little lopsided, but I just got around to measuring it tonight. It's sitting about 5/8" lower on the driver side, both front & back as measured at the top of the wheel wells. I replaced the springs with 1/3 drop coils from Chassis tech, new cab supports, new radiator support mounts, new ball joints and upper A arm bushings. The radiator support has a little bend in it that might be contributing to the problem, but I don't think that it's the only culprit. I've also changed over the bed cross sills to used ones from a wood bed.
Do you all think that I just need to start shimming, or are the spings not propperly seated or what?
I can do all things thru Christ, but he evidently doesn't want me to beat that Camaro light to light.... |
12-21-2003, 09:53 PM | #2 |
Robert Olson Transport
are you sure the lower control arm bushings are good other than that the springs not seated is the only other thing i can think of
12-22-2003, 01:18 AM | #3 | |
Bloo
did you put the parts on, leave the bolts slightly loose, then torque them after it was on the ground with weight on it?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
12-22-2003, 02:15 AM | #4 |
Uh, I don't think so. It's been a while since I put all this stuff together. Do you mean the suspension parts? They were pretty much torqued up when it came off the jack.
12-22-2003, 02:23 AM | #5 | |
Bloo
woops, yeah i ment the suspinsion stuff
its supposed to be tightened most of the way in the air, put on the ground with the trucks full weight on it, then torqued down completly dont ask me what, but there is something that makes it sit lopsided if you torque it in air (cant remember--thats why i said dont ask me )
12-22-2003, 02:57 AM | #6 |
are you sure it is on level ground?...
I just finished putting 3" lowering coils and ball joints in the front of mine. I measured before and had 31.25" driver side and 30 .75" passenger. after i finished, I backed up the truck in the drviveway and had 28.25 on both sides. thought my original coils were off but when I pulled it back into the place I did the original measurement...it was still lopsided. I dont think 1/2 inch is visable to the eye.
Haleiwa, Hi. 1972 Custom Camper Cheyenne Super c/20 Longhorn 402bb 78k a/c, tach, tilt, tool stowage 48panhead 74 bronco 71 bronco http://noscade.com No Scade is pidgin English for "not scared" similar to "no fear". |
12-22-2003, 11:17 PM | #7 |
It's setting in the garage on a concrete floor and if you look at it from the rear (say about twenty feet away) it definately looks cockeyed. Like I said, it's about 5/8 inches lower on the driver's side, so I can only assume that it'll be worse when it gets a 180 pounder (me) behind the wheel.
Exactly what suspension parts need to be torqued with it on the ground? Maybe I'm just being dense, but I've looked at this thing quite a bit and I can't see what could be binding up that would make it sit lopsided in both the front and the back by the same amount. Maybe this is a dumb question, but could it just be that since nobody has set in the passenger side since I changed the springs that they haven't settled as much as the driver's side yet?
