Old 04-15-2021, 02:19 AM   #1
Asshat
Asshat's Avatar
Brake line selection - what size, material, etc..
Looking for a good explanation and recommendation for running brake lines. Planning the cross member swap; I’ll have discs up front (from a 74 C20) and rear drums (from an 83 C20).
Really just concerned with running the front lines, properly flaring the tubing and using the correct fittings and tees. I believe steel is the easiest to work with; I figure I’ll probably need no more than a 25’ roll.
Also, 1/4” ok to use for front discs from master cylinder, all the way to the back tee?
Seems like there are so many options out there. Any help would be appreciated.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
