12-21-2003, 09:12 PM | #1 |
faster, faster, faster
I need stiffer front shocks
I am having trouble with my wheels rubbing on the inner fender wells when I hit bumps. The shocks on the truck are crap, they have way too much travel. My truck is lowered about 5 inches up front and I am running 255/55 18's. What do you guys recommend as far as an adjustable shock that I can adjust to the stiffness I am looking for?
Edited to describe problem better: When I am driving and hitting normal bumps it is ok, but when I hit a large dip in the road, or a seam in the highway that has created a large dip I get wheel rubbing. This does not happen over normal bumps, my shocks are just worn out and I am looking for some stiff adjustable shocks to get a stiffer ride. They can have 15 inches of travel for all I care, I just want to be able to limit it with the pressure settings.
I'm going to Law School, wanna debate? It's good practice. Last edited by my new 72; 12-22-2003 at 10:45 AM. |
12-22-2003, 12:54 AM | #2 |
So no one has any suggestions or past experiences about this?
I'm going to Law School, wanna debate? It's good practice. |
12-22-2003, 01:09 AM | #3 |
http://www.doetsch-shocks.com/lowtruck.php
you probably need somethign they have
70 longbed 496/th400/Ford 9" |
12-22-2003, 01:11 AM | #4 |
http://www.sporttruckdirect.com/Doet...ch_shocks.html buy them there
12-22-2003, 01:21 AM | #5 |
Using shorter shocks as suspension travel limiters will just ruin them. I suggest you adjust your bumpstops. I have pulled out the springs and cycled the suspension. Rest the vehicle on the stops and set them to limit the suspension a little more than that. Using the longer shocks is fine as long as the suspension has the travel you need and the shock is not bottoming or topping out. A longer shock has more oil in it and will be less resistant to fade. As far as shock brand for a stock or lowered 2wd i always use KYB's, great shock for the money IMO. Might want to look into a different wheel if it is out to far (less back spacing). Obviously a shorter tire would give you more room also.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
12-22-2003, 02:10 AM | #6 |
I didn't mean shorter shocks, I meant a stiffer one. I'm not going to buy new tires and run rubber bands because of this either. I just wanted to know of a good STIFF shock with about three inches of travel to keep this from happening.
12-22-2003, 02:28 AM | #7 |
shocks ain't going to solve your problem
12-22-2003, 02:37 AM | #8 |
I am not sure how you think that a stiff shock is going to solve your rubbing problem? A unit with only 3" of travel is very short and it sounds like you want to use the shock length to keep the suspension from moving to much, which is a bad idea. The wheels and tires were just a suggestion, you asked for them. You need to mechanically prevent the suspension from cycling to far no matter how "stiff" the shocks are. As I said before I like KYB's I think they offer a good compromise between ride and handling. Good luck.
Upon reading dinnut's post I realize that I may have given you more information than you wanted By your second post it seemed that you wanted suggestions regarding the rubbing problem not just the shocks
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 12-22-2003 at 03:56 AM. |
12-22-2003, 03:21 AM | #9 |
i gave what you asked for. lowering shocks or something "hard" i figured that is what you needed since ur truck is lowered.
12-22-2003, 04:18 AM | #10 |
Shocks can definitely help you out. But only if you only rub when you hit a bump hard. Then you can get a stiffer shock that will "limit travel" by applying more downward force from compression damping. A shock will have a certain force when it sees a velocity. Higher velocities will exert higher force. So when you install a stiff shock it can effectively "limit" your travel.
From the Doetsch link above, I found an adustable shock that I think I will actually buy. I've been looking for some and I think I like these ones. They are a 9 position adjustable shock. That means you can keep adjusting it so it is the exact stiffness you want! Hope this helps.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
12-22-2003, 10:16 AM | #11 |
Thanks Dinnut and Injected68LS1, that is exactly that problem I am having. It's only when I hit a good dip in the freewy or streets that causes the suspension to travel all the way up. Whatr is the number of those 9 way adjustable shocks you found? They sound exactly like what I am looking for.
12-22-2003, 12:54 PM | #12 |
You should actually give them a call. It looks like they have 4 or 5 different styles of shocks that you can order with the adjustable valving. Let me know what they recommended so I can get some too.
12-22-2003, 07:33 PM | #13 |
Will do, Injected, I'll let you know.
