04-17-2021, 11:45 AM | #1 |
Window sweeps sit too low in door
I’ve done a search and found guys on the 60-66 side have had the same issue. My inner door “fuzzy” sits just about perfect. The outer door window sweeps sit too low. The rubber does not sit on the door top ledge on the outside. It sits down inside the door. What is the fix or solution? These are precision brand purchased 5 years ago. I was thinking of cutting the clips off and applying 3m double sided tape to them. I also found a company making glue on outers. https://www.fatfendergarage.com/prod...ndow-seal-kit/
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
04-17-2021, 12:17 PM | #2 |
Re: Window sweeps sit too low in door
I have precision, about 10 years old now. The chrome edge sits about level with the top door edge, the rubber sits below. Does make good contact with window when rolling up. There is no space or rubber visible between the chrome edge and the door.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-17-2021, 12:49 PM | #3 |
Thank you for the reply. Seems like a silly design as it creates a channel for water to sit in and eventually go into the door. All other window sweeps sit on top of the door so the water funnels away.
Posted via Mobile Device |
