Old 04-17-2021, 10:08 PM   #1
Asshat
Asshat's Avatar
Front brake hose fitting 74 C20
Can anyone tell me what fitting would go on this line?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 04-18-2021, 09:51 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Front brake hose fitting 74 C20
Is it for a 74?...most likely not metric...maybe...
Are you referring to the line fitting size
I'm guessing the line size will be 3/16...which most probably will have a 3/8-24 thread size fitting on it.. be aware, you can also get different thread size fittings for 3/16
Or are you referring to the od threads?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-18-2021, 09:59 AM   #3
mongocanfly
Post Whore
This shows maybe 5/8 fine thread for the od threads...
http://67-72chevytrucks.com/vboard/s...d.php?t=177184
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-18-2021, 11:55 AM   #4
Asshat
Asshat's Avatar
It’s a 74 C20 cross member, going into my 63.
Just not sure what fitting I need to go to the brake lines.
Hoping someone here can post a couple pics.
292, 4-speed
Old 04-19-2021, 10:22 PM   #5
mongocanfly
Post Whore
Should be 3/8-24 inverted flare brake line fittings
The ends will look like this
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-20-2021, 07:23 PM   #6
Sabaka454
Sabaka454's Avatar
From the factory, a stamped nut was used but you can use a 5/8"-18 nut
Sabaka454 is offline   Reply With Quote
Old 04-20-2021, 08:48 PM   #7
Asshat
Asshat's Avatar
I think I can just use what’s on the truck when I swap the cross member.
292, 4-speed
Old 04-20-2021, 09:39 PM   #8
kwmech
5/8-18 jam nut to hold the hose to the frame and regular 3/16 brake line + fittings for the hard line
