Taillight bulb numbers
Finishing things up, opened my new taillights (bought 3 years ago) and the bulbs are not working. No real numbers on the bulbs, just "12V". I tested them and they are dead, filaments are broken. Can someone tell me what are the correct number bulbs go in these lights? They are aftermarket 12 volt lights.
![]() Join Date: Jul 2007
Re: Taillight bulb numbers
1157 is the standard two element tail light/stop/turn bulb.
2357 is the brighter replacement for those. Note: if the insides of the housings are painted black do yourself a favor and paint the inside of the housing bright white from the start. That alone will make your tail lights a lot brighter. Remember that you have to have a real good ground for the lights. A lot of time they don't ground to the bed or body because the paint insulates them too well.
#3 | |
![]() Join Date: Aug 2010
Let’s clear things up , what tail lights do you have , what year , stock or custom.
Post a picture of them . The 1157 fits the ‘55 up Task Force tail lights .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
Sorry. The truck is a 1953 3100, aftermarket replica taillights.
An 1157 bulb or a direct but maybe brighter replacement is going to have two contacts, two elements and staggered pins to hold it in.
Still how are you testing the light? If it has two wires and you are putting one to pos and one to neg that will not work. You have to put one to pos and ground the housing to neg. Most guys run a ground wire from the housing to a good clean bare ground on the truck to get a good ground. Some lights come with a third ground wire built in.
#7 | |
![]() Join Date: Mar 2012
Post a picture of the bulb and / or the light for better help. Maybe you have a receipt with the light number and the vendor name? Maybe the lights came in a box and there's a number on the box? Heck, I'm not even sure if there's a picture of your truck available if someone wanted to do the work for you. Last edited by 1project2many; 04-20-2021 at 09:00 AM. |
#8 | |
That means you bought some off the wall tail lights that have who knows what for bulbs. We have told you what normally fits all regular oem or repro AD truck taillights. First I would go back to the add I bought the lights from and see if they tell what bulb it uses. 1157 base is 15mm in diameter, you might want to take your calipers out and measure the diameter of the bulb you have. Most every double element bayonet mount bulb I can find is a 15 MM BA15D mount. This chart shows about every small bulb currently available for 12 Volt automotive lights. https://hlgroup.fi/wp-content/upload...Wall-Chart.pdf
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 04-20-2021 at 01:19 PM. |
a pic says a thousand words and only takes a sec to take and post. it would really help us help you. if you don't know how to add a pic to the thread just ask, or check the "pics and how to post" thread
http://67-72chevytrucks.com/vboard/s...d.php?t=818026 is the bulb socket round with 2 grooves down each side to accept the bumps on the outside barrel of the bulb? does the wiring contact at the bottom of the bulb socket have 2 contacts? or, is the bulb holder made to accept a flat style "push in" bulb contact possibly? https://www.bulbs.com/product/1157B2 https://www.bulbs.com/product/3157LL...U-20-BX-200-CS you could easily enough update the bulb socket to fit an 1157 bulb if you want or need to. I don't remember seeing anything that mounts with screws for the 3157 bulbs https://www.memotronics.com/bayonet-...-orthagonal-1/ anyway, keep us posted if you still need help or have it figured out now. close the loop sorta thing out of respect for those who give advice, spend their own time researching for you and would like to know if it helped or not and whether you have it figured out. |
3157 Has a rectangular base Those bases are usually plastic and could be installed in a different housing with an adhesive if needed. I put a pair in some travel trailer tail lights a few years ago.
I'd agree we need some photos of the actual bulb and a clear photo of the socket.
#11 | |
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
I spent over two hours looking for a bulb that might fit. I'm beginning to think he has some sort of motorcycle taillight rather than an an oem style truck tail light.,
#13 |
This is it. I've for some lamps that will work. Thanks to all who helped.
https://www.classicparts.com/1941-53...tinfo/49-120R/ |
#14 |
You didn't break the bulb off in the socket? Leaving the metal part?
When you look in the socket you should see the two contacts
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 04-22-2021 at 09:30 PM. |
#15 |
I bought these LED tail lights for a 1956 https://www.classicparts.com/1956-59...info/49-130LR/
They had a 1157 style bulb base put into a 1157 style socket then output to a pigtail coming out of the tail light housing. They did not work right out of the box. Ground was not good going through those 1157 style adapters. So we cut all that junk out and rewired straight through. More foreign junk, but it works now. And the stainless steel housing is nice (unless it starts to rust LOL)
#16 |
hey driver_wt, do you happen to have a pic of the inside of the lights you used before the mod was done so mountaineer can have a look and say yes or no to a match of what he has? still no pic of the problem light so we are all just guessing and spitballing fixes. the link to classic parts only shows the outside of the light, awesome marketing job there.
#17 |
This appears to be the same light:
https://www.americanclassic.com/mobi...nfo/49%2D120R/ They sell this bulb as a 6V replacement: https://www.americanclassic.com/mobi...info/54%2D105/ This is a single filament tail only bulb. A 12V version of this bulb could be 1155 or 67. Both are similar intensity. A 1003 uses the same base and is brighter but is also hotter and has slightly larger glass. You can look at #67 bulb in this Amazon ad: https://www.amazon.com/67-Automotive...omotive&sr=1-2 Edit: This appears to be a Dynacorn LP19 based on the wire color and cloth insulation. Most other lights do not include the cloth. But the inside of a different reproduction light can be seen here: https://www.classychevusa.com/index....od/prd1082.htm Last edited by 1project2many; 04-23-2021 at 04:25 PM. |
#18 |
Two single element bulbs with different wattage. I'm thinking that is going to end up taking a trip to the parts house with tail light and sample bulb in hand.
It's going to take some with around 8 watts for the tail light and 27 for the stop/turn bulb. https://www.bulbamerica.com/collecti...t_by=relevency
#19 | |
| Bookmarks |
