Old 04-22-2021, 12:59 PM   #1
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
What grease for distributor advance mechanism?
I've decided to rebuild an HEI for an upgrade to the old inline 6 ,so what is the correct type of grease for the advance mechanism?
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 04-22-2021, 01:07 PM   #2
mr.mud1
mr.mud1's Avatar
Re: What grease for distributor advance mechanism?
hi Chris,i've seen lots that had none but i'm sure the factory used something?i use a dab of lubriplate or white grease on the pins and on the little round plastic buttons under the weights,although they probably are self lubricating.if you do put something there,you don't want much as it'll sling around and make a mess.Greg
mr.mud1 is offline   Reply With Quote
