04-23-2021, 10:00 AM | #1 |
can I use a standard auto column with an ls swap?
My truck came as a three on the tree. That was all removed for painting. I picked up a standard auto column a while back. Is this easy to retrofit into the cab and connect up with the standard ps box? I installed a normal 68 power steering box using a write up here on the forums. All I had to do was dent in the frame a bit and it went right in. I plan to use the ls power steering pump to feed the ps and the hydraboost from the 2000 truck i took it out of. Pic of my steering column attached.
04-23-2021, 10:01 AM | #2 |
Re: can I use a standard auto column with an ls swap?
Oh, and I'll need to somehow get this to shift my 4l80e
04-23-2021, 10:36 AM | #3 |
Almost Satisfied
It should bolt right up. I used the Lokar lingage for my 4L80e. There are some fitting differences between OE and Metric on the hydro boost and your stock steering gear, but you can find a lot of threads on this. I ended up having the hoses made for mine at my local machine shop.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
04-23-2021, 11:30 PM | #4 |
All about them K’s
There’s info on the hydroboost swap in post 161 in the build thread for my 72 K20 linked in my signature. I used a hydraboost from an 09 or so Chevy 2500HD.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-24-2021, 12:42 AM | #5 |
"Can I use a standard auto column with an ls swap?"
YES |
04-27-2021, 06:54 AM | #6 |
If you use the later square body steering box, it will have the same fittings as your pump and hydroboost. 82ish should work.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
04-27-2021, 01:47 PM | #7 |
I bought 6an fittings and adapters along with black braided SS hose of the entertainment and made my own a lot less money
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
