Old 04-23-2021, 12:55 PM   #1
mi396ss
SM465 Stuck After Removing Shifter
I removed my shifter to make it easier to install new carpet. Now that the carpet is in I put the shifter back on and it won’t move at all. Does anyone know what’s going on with this? Thanks
mi396ss is offline   Reply With Quote
Old 04-23-2021, 01:29 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: SM465 Stuck After Removing Shifter
Did you have the lever in the neutral position when you removed it? It sounds like the inside ball end is outside of the shifter forks. You will have to pull it back out and make sure the lever shaft is straight up and down when you put it back in. If you did not have it in neutral you will have to figure out what gear you had it in when you removed it and put it back in with the lever in that position.
LockDoc
Leon
Old 04-23-2021, 03:14 PM   #3
mi396ss
I didn’t pay attention what gear it was I wen I removed it. It’s odd because it drops right in and I can lock it in fine, just can’t move it. So you’re saying if it was in 3rd gear when I removed it the stick would have to be in the position of 3rd gear when it goes back in? It’s seems to only drop in place in one specific spot.
Old 04-23-2021, 04:31 PM   #4
mi396ss
After some finagling I got it. Thanks for the help.
Old 04-23-2021, 04:49 PM   #5
LockDoc
LockDoc's Avatar
Good deal. Glad you got it installed.
LockDoc
Leon
Old 04-24-2021, 10:04 AM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Did you have to move the forks to neutral?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-24-2021, 01:05 PM   #7
mi396ss
No, I didn’t touch the forks.
