Old 04-23-2021, 09:50 PM   #1
speedbucket
speedbucket's Avatar
Power assist steering to full power
I have a 1967C 20 with power assist steering, I need to fix it so I will stop leaking. Can I make this a full power steering with a box from a later vehicle?
speedbucket is offline   Reply With Quote
Old 04-23-2021, 11:52 PM   #2
chewychevy67
Re: Power assist steering to full power
Yes you can. Lots of stuff on here that shows a few ways to mount a newer ps box onto a 67 frame. You can use spacers or dimple your frame. The bolt pattern will mount up. Where is the assist leaking? Does it work ok?
chewychevy67 is offline   Reply With Quote
Old 04-24-2021, 03:14 AM   #3
speedbucket
Thanks chewychevy67, yes it works but leaks bad I think from the pump.
Old 04-24-2021, 02:59 PM   #4
speedbucket
I’ve read here that there are rebuilding kits from corvette and impalas that work on the power assist rams. I think it may be better overall to change it to a power steering box from a later year.I had power assist on my 67 Mustang convertible and it was always leaking and never stopped leaking even after rebuilding.
Old 04-24-2021, 07:16 PM   #5
68racer
Yeah baby!
68racer's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=365817
11.37 @116
68racer is offline   Reply With Quote
Old 04-25-2021, 02:36 AM   #6
Greasey Harley
Greasey Harley's Avatar
Is this what you need?
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 04-25-2021, 04:03 AM   #7
speedbucket
Yessir ��
