04-24-2021, 02:13 PM | #1 |
Adding door switches for curtesy lights
I am considering adding door switches for courtesy lights.
Did any of the 67 to 72 trucks come with the door switches installed? Are the switches a standard tap size? How do you run the wire out from the inside of the panel to the interior? My truck has the boss in the body but it isn't drilled. Thank Rick Last edited by Accelo; 04-24-2021 at 02:23 PM. |
04-24-2021, 03:12 PM | #2 |
All about them K’s
Re: Adding door switches for curtesy lights
The higher trim trucks (Cheyenne and Cheyenne super for sure) have them factory, you can buy the switches and harness plug and play. I would get the blazer style floor courtesy lights setup if I were you. That’s what I’m adding to my Cheyenne K20. The kit below is the blazer style lights but it also runs the dome light too.
https://www.cjponyparts.com/painless...RoCltoQAvD_BwE
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
04-24-2021, 05:27 PM | #3 |
I have the same kit listed in your url.
Only mine was included in the American auto wiring kit. Only difference is no switches were included in the kit. Still interested in how the factory did the wiring routing. Rick |
04-24-2021, 05:52 PM | #4 |
All about them K’s
Door switches are available from Napa. Give me a bit and I’ll dig up the par number. The wires go thru the kick panel, I can post pictures in a bit as well.
04-24-2021, 06:09 PM | #5 |
All about them K’s
Wire routing
Driver first, passenger second
04-25-2021, 02:19 AM | #6 |
Thanks 57taskforce.
Just what I was looking for. My package of misc grommets just arrived. Looks like I will get to put a couple to use soon. The Board is such a great resource. Thanks everyone. Rick |
