04-25-2021, 09:13 PM | #1 |
Gear Vendor Emergency Brake cable interference
Happy Sunday All.
I have searched without luck on this subject. Just eyeballing the existing location where the GV would mount to my NP205 transfer case (‘70 SB K10 3x4), it appears the factory E brake cable setup will occupy the same spot and relocating the Ebrake set-up does not appear to be simple at all. Anyone have experience with this issue? |
04-26-2021, 02:43 AM | #2 |
Re: Gear Vendor Emergency Brake cable interference
If there is enough slack in the cable when not engaged. I would just integrate a guide or stand-off for the cable to slide on over the gear vendors unit.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-26-2021, 09:30 AM | #3 |
On the road
I don't think this will help you, I have a 2wd and a automatic trans. My cable goes under the GV and clears but it does rub.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
04-27-2021, 12:11 AM | #4 |
No pics... but my GV Unit is behind a SM 465 and I did have interference, I just installed the GV Unit then basically made/moved a few parts to go around it.
04-27-2021, 02:54 PM | #5 |
Shortbed or longbed? Buy one of LNC's parking brake cable repair kits (34-3063), then lengthen the threaded portions until the cross over section clears and remake the cable
