Old 04-26-2021, 09:37 AM   #1
Bbarbeau
Correct Valve Covers for 72 SB
I'm going to replace the aftermarket valve covers on my 72 and want to make sure I can get the right ones.
Am I correct that the 71/72s had the rubber oil fill? Would anyone with a 72 have a photo?
Thanks!
Brad
72 C20 Highlander, 350
Bbarbeau is offline   Reply With Quote
Old 04-26-2021, 11:10 AM   #2
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Re: Correct Valve Covers for 72 SB
Yes 72 has the rubber oil fill plug. Sorry I don't have a photo handy
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 04-26-2021, 08:14 PM   #3
72 Super
72 Super's Avatar
Here is a picture of a set of correct 72 valve covers. Most if not all of the 71 and earlier valve covers are the 3 hole versions.
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 04-27-2021, 06:01 AM   #4
Bbarbeau
Thanks to you both.
72 Super, just to clarify - 72 were four holes then as the pic shows (2 on each side that match)?
____________________
Old 04-27-2021, 07:25 AM   #5
72 Super
72 Super's Avatar
Originally Posted by Bbarbeau View Post
Thanks to you both.
Yes 72 had four holes.
On the passenger side looking from the front of the truck.
Rear hole is for the air cleaner hose
Front hole is the oil cap.
Drivers side
Rear hole is for oil cap/ or oil fill tube (AC trucks)
Front hole is for the PVC valve.
Old 04-27-2021, 04:08 PM   #6
Bbarbeau
Oh thanks, I totally thought it was just three!
Drivers side
Old 05-02-2021, 01:01 AM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
If you have a 350 engine and factory A/C the A/C bracket goes right over top of the hole on the pas side front so its just capped.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
