Old 04-27-2021, 03:21 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Does this look like the correct inner fender wells??
1969 GMC 3/4 2WD.
Went on a shopping spree this weekend with my over time money.
Looking over the parts I bought. Got most of what I needed this time around, but they only had the passenger side fender well. I don't have the old ones to match up with. Also, besides the fender, where else does this mount to?? Thanks.
desert-rat is offline   Reply With Quote
Old 04-27-2021, 04:40 PM   #2
my67c20
Re: Does this look like the correct inner fender wells??
Yes, that is correct. 2 holes on top mount to fender, square hole is to frame, holes in front to core support and holes around wheel arc go to fender. If this was drivers it would have some mounting holes for an L-shaped bar to mount around steering shaft
my67c20 is offline   Reply With Quote
Old 04-27-2021, 04:50 PM   #3
sick472
sick472's Avatar
I believe my67 meant to say the the square hole is where it mounts to the cab frame. I'm not even sure what is is called. Cab Sub Frame, maybe?
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 04-27-2021, 06:09 PM   #4
desert-rat
Well that's a relief to know that I got the correct fender. Gotta get the driver side in 2 weeks. Its on back order. I'm over here trying to line up the holes to the frame. Lol. I forgot it doesn't mount that way. Thanks for the replies.
Old 04-27-2021, 09:39 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
This is what the bolts look like that fit into the square holes and into the cab brace. The washers are about 2 1/2" in diameter.
LockDoc
Leon
