04-30-2021, 10:27 AM | #1 |
BLUEPRINT Engines - thoughts comments - Fully dressed LS
Would like some comments/ experience with BLUEPRINT ENGINES
I already have a PSI - LS3 harness and will be running a 6L80e trans with 208 case - I will send the harness back to PSI for setup with the BLUEPRINT parameters. Considering running one of these two in my K5 build 376 CI - LS3 - 6.2L - 530HP, 495FTLB https://blueprintengines.com/product...-psls3760ctfkb or 408CI - LS3 - 6.0L - 585HP, 540FTLB https://blueprintengines.com/product...on-bpls4080ctf
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
04-30-2021, 02:54 PM | #2 |
Re: BLUEPRINT Engines - thoughts comments - Fully dressed LS
What is your planned usage for the truck? Any power adders, etc? I have a blueprint 427 small block and it has been doing great for me. My brother installed quite a few when he was working at a hot rod shop as well. The ls stuff is stout from the factory too, the forged stuff in the 408 is sweet, but if you're not going to be running the piss out of it or adding a power adder it's a little over kill. The warranty with a crate is sweet, have you looked at some of the other builders, Texas Speed, Thompson motors to name a few?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
04-30-2021, 04:45 PM | #3 |
I would go over to LS1tech.com and ask the same question.
04-30-2021, 05:13 PM | #4 |
No future power adders - 500hp or more is enough
Street driven, cruiser that's all...… drive 2-3 times a week 30 - 40 miles
05-01-2021, 09:29 AM | #5 |
I have one of their 400 SBCs. I love it and would recommend them without hesitation. I know this is an LS, but just giving my opinion.
05-01-2021, 04:31 PM | #6 |
After looking at the specs on both I would want forged pistons on the LS3 at that price level. On the 408 the cam has a fair amount of duration. I would ask Blue Print what is the idle vacuum if you are planning running stock type power brakes.
05-03-2021, 10:38 AM | #7 | |
What is the minimum to run a power brake booster?
05-03-2021, 02:32 PM | #8 |
Post Whore
16-18 inches according to the net..but I think the size of the booster plays into it as well...
Personally, I'd use hydroboost...I love mine
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-03-2021 at 02:44 PM. |
05-03-2021, 04:49 PM | #9 |
At 9.5" of vacuum your power brakes won't work. Don't try to band-aid it with a vacuum cannister. Been there done that. You could use a electric vacuum pump. With your some what heavy rig I would spend the money for a hydro-boost as said above.
I've done a couple hydro-boosts on my hot rods. Bought them from Hydra Tech as a complete kit. Others go junk yard diving and build their own. If you have rear drums you need to check and see if a hydro boost will work. I had discs all the way around on my projects. |
05-03-2021, 08:38 PM | #10 |
Post Whore
Hydroboost works great with rear drums..as long as you have a disc/drum master and prop valve, it's good to go..
05-04-2021, 10:42 AM | #11 |
Does the standard LS powersteering setup work with Hydroboost - looking to run the below accessory kit
https://blueprintengines.com/product...brackets-bolts https://www.cvfracing.com/black-chev...ower-steering/
05-04-2021, 11:03 AM | #12 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
05-04-2021, 11:17 AM | #13 |
will the pump that is linked work ? Looking to get the entire setup through BLUEPRINT - not sure they'll know or not.
05-04-2021, 04:17 PM | #14 |
Further down on the page in the application notes for engine there is something that says "Compatible with Hydroboost ($275 option)" Not sure what that consists of. But evidently they are aware of hydroboost.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
05-04-2021, 04:35 PM | #15 |
Post Whore
There may be internal differences, but on mine the only diff I could see was the extra return port
05-04-2021, 05:26 PM | #16 |
My hydro boost swaps one 67 Nova and I used a stock "ham can" power steering pump. On my 66 Mustang hydro boost swap I used a KRC pump.
Before you buy a power steering pump I really would call Hydra tech and see what they say would be the best. I have no interest in Hydra tech other than then they gave me great tech advice. |
