04-30-2021, 07:33 PM | #1 |
2" lift on a 72
anyone running a 2" lift on a 67-72? I need a measurement if possible. a straight line between the two bolts, and a measurement from that down to the bottom of the spring where it mounts to the diff. need to figure out the arch with it sitting on the springs.
Don't have a truck to measure here right now. Thanks if you can help.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-01-2021, 07:37 AM | #2 |
Re: 2" lift on a 72
I have off road design 2" front springs. There actually still a reverse arch because the pack is so thick. Not sure if that helps..
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
05-01-2021, 11:20 AM | #3 |
Re: 2" lift on a 72
Ok. thats interesting. I don't have a stock vehicle to compare to. I need some measurements as I'm trying to determine what lift to use for a different kind of vehicle. these springs are the correct length, just need to figure out what size lift I need to order to get it where I want it.
05-01-2021, 12:22 PM | #4 |
All about them K’s
Re: 2" lift on a 72
Let me see what I can dig up. My Shorty K10 has a small lift. I’ll see if I can figure out if it’s 2 or 4”.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
05-01-2021, 06:36 PM | #5 |
Re: 2" lift on a 72
ok thanks.
05-21-2021, 10:14 AM | #6 |
Re: 2" lift on a 72
Check out Skyjacker and Superlift. These are just some of the cheap lift kits that you can install on a classic Chevy truck. Just not sure if both have it in 2-inch versions.
05-21-2021, 11:04 AM | #7 |
Re: 2" lift on a 72
You can get 2'' just by taking your springs to a spring shop and having them re-arched
05-23-2021, 12:31 PM | #8 |
Re: 2" lift on a 72
don't have any stock springs. I'm looking to use them on a different style project, and need to know how much height the spring is at when its installed.
I hate to spend 400 for 2" springs if 4" might be the ones I really need.
