Old 12-22-2003, 01:37 AM   #1
72superBB
72superBB's Avatar
Replaced intake gasket, now what?
If you have been following me, I have found the problem. I pulled the intake tonight. The back drivers side bolt was not even tight and it had some light brown mucas all over it. There were other bolts that were not really tight as well. I pulled the rest of the bolts out and pulled of the intake. There was rust all over the back drivers side area around the water port. There was coolant sitting on the top of the motor as well.
I am going to change the oil Monday night. I also replaced the thermostat as well. How long should I drive it around before I change the oil again. Should I change the filter both times as well? I hope this is the problem I have been having.
thanks for your input!
Ron
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 12-22-2003, 01:52 AM   #2
rage'nrat638
rage'nrat638's Avatar
DID YOU....
smear silicone sealer around the water ports on the head and intake before reinstalling......
DID YOU ....
NOT USE THE RUBBER FRONT AND REAR GASKETS WITH THE GASKET SET .....
and instead only use silicone on them.....
DID YOU....
coat the intake bolts w/silicone....mostly the four center ones
TWO on each side of the carb flange base....
they go all the way through on a small block......
JUST WONDERING
AND RETORQUE EVERY THING
change the oil after 500 miles.....you did change it now right???
rage'nrat638 is offline   Reply With Quote
Old 12-22-2003, 04:23 AM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
^^^^^ Yes, Yes, what he said!! Also Yes change the filter!!!! The filters are the life of an engine!!!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
