Old 12-22-2003, 01:45 AM   #1
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
72 1/2 ton 4x4 (327/t350/np205)
Ok, I have had this for sale a while. The price is moveable, but every penny of it will be used for this semester of college. I originally had it posted at 1800$. It runs, and drives. Has some problems. But i used it this summer to goto the mountains, etc. Here are the specs.
1968 327 block
flat top pistons
1995-6 SBC Heads, have 10k miles on them
Has stock cam in good shape with new lifters
HEI dizy that gives a hella good spark.
Quadrajet 4 barrel and cast manifold(modded to the new heads and doesnt leak)
Headers ( does have a leak, needs a bolt tightened)
True Duals out behind tires
Turbo 350 tranny
Was rebuilt by me. I have used it and works. It probably wont hold up to abuse. Its just a stock rebuild.
NP205
works great. It leaks some, but everything here does. Not major enough to cause problems.
Has lockable hubs in the front, which work.
4x4 works fine, i had to use it a few times.
Is currently in 2 colors, The fornt clip is orange(factory) The cab is a factory blue and white. The bed is a matching blue. There is rust there. The rockers will need work, the windsheild is fine, and the floors look BRAND new. I have some spare parts i would through in.
Now, the things wrong with it, are the tranny dipstick will leak fluid if you park with it low on the passenger side. I just havent got around to fixing it. Doesnt affect it when its running though. The Engine runs good, but the valve stem seals are drying up on it. It hasnt got started since i came to college probably. However, it would start right up if the battery is still up. The interor... well looks like a farm/hunting truck, i used it to hunt. Has some good tires on it. The title is mine and will transfer it. Anything i missed?? This can be ran right up on a trailer, it will run. I wouldnt drive it accross the country though. I changed the oil in it often, and it has new plugs, cap rotor, etc. Im wanting a bottom dollar of 1400$. From what ive seen sold on here i think this is a steal. It runs and drives under its own power. Has power steering, power brakes. I dont have pics right now. Its currently located in jerome, idaho. I would be willing to drive/trailer it for the gas. Any questions jmartin@uidaho.edu Thanks!!!
BTW, long box
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 12-23-2003, 12:25 PM   #2
Heavy-Chevy
That would be a deal!!
It is for a good cause. hpoefuly some will get it.
TRUCKS & Autos that run:
1972 GMC Sierra Grande 3/4ton LWB 4x4
1972 Chevrollet K/5 with a 6"Lift, 462 heads "money pit"
1988 K3500 Crew "Big Red" 4x4
PARTS OR PROJECT TRUCKS:
PARTS for sale or trade:
WANT :
1972 parts blazer/Jimmy parts truck
1967-72 Parts Chevy/GMC Truck
NEED stainless hubcap for 3/4ton GMC
Heavy-Chevy is offline   Reply With Quote
Old 12-25-2003, 03:20 AM   #3
stelth2002
stelth2002's Avatar
Ok, I've emailed everyone back thats emailed me. Anyone else interested in this bueaty?????
Old 12-26-2003, 03:26 PM   #4
stelth2002
stelth2002's Avatar
pic
Old 12-26-2003, 03:29 PM   #5
stelth2002
stelth2002's Avatar
sdf
Old 12-26-2003, 03:36 PM   #6
stelth2002
stelth2002's Avatar
wt
Old 12-26-2003, 03:36 PM   #7
stelth2002
stelth2002's Avatar
dfgh
Old 12-26-2003, 03:37 PM   #8
stelth2002
stelth2002's Avatar
refg
Old 12-26-2003, 03:38 PM   #9
stelth2002
stelth2002's Avatar
df
Old 12-26-2003, 03:39 PM   #10
stelth2002
stelth2002's Avatar
The black stuff in this picture is the factory stuff that goes over the floor. I peeled this up and it looks new.
Old 12-26-2003, 03:40 PM   #11
stelth2002
stelth2002's Avatar
sdfg
Old 12-26-2003, 03:41 PM   #12
stelth2002
stelth2002's Avatar
as
Old 12-28-2003, 12:16 AM   #13
robby
Semper Fidelis
robby's Avatar
Looking a little closer, is this a hybrid truck of different years? Doors look like 67-68 trim and the rear view looks like it is bolted to the cab roof where a 72 would be glued on the windshield. Does it have disc brakes? What does the grille look like? Do you have any of the correct engine brackets or the fan shroud? Wheel type and tire size? any other options? Thanks
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
