Old 12-22-2003, 02:12 AM   #1
orange72
orange72's Avatar
pushrod slot
ok guys ive got a question. me and my dad are doing an engine swap right now and ive got a point that i have a question. were pulling the engine out of my 72 and putting an engine in out of a 84 chevy. the question is is that the pushrod slot in the 84 seems to a have a lot my side to side play in it than my 72. also the 84s rocker arms look to have sorda a slot to keep them centered on the tip of the valve. but im not putting stock rocker arms on it. im putting comp cams magnum roller tip rockers in it which worked fine on my 72 but will they work ok on the 84. it seems with all that play from side to side that they would work there way off the valve and wear something out. anybody thats got any information would be greatly apreciated. oh and by the way the engine is a small block 350.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 12-22-2003, 02:15 AM   #2
rage'nrat638
rage'nrat638's Avatar
that happened to the 305 that was in my 85....the lifter would not stay on the valve tops....heads were junk.....
unless you change to 7/16 studs and go with push rod guides
rage'nrat638 is offline   Reply With Quote
Old 12-22-2003, 02:20 AM   #3
orange72
orange72's Avatar
or go with stock rockers. but there not worn..it looks factory.
Old 12-22-2003, 02:52 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It sounds like your rockers are the self-aligning type. Chevy went to them in later years. Your heads might have been changed.
They will have two nibs on each one to keep the rocker centered straight on the valve tip.
