Old 05-02-2021, 05:15 PM   #1
Asshat
Asshat's Avatar
Power steering pump pulley install question
Is this a special nut for the pulley? It measures 14.1mm.
https://www.classicindustries.com/product/mn7512.html
Also, is the prong required for the shaft? Looks like the shaft already has a seal; it’s a rebuilt ps pump.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 05-03-2021, 07:43 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Power steering pump pulley install question
Simply install the key on the shaft and slide pulley on and tighten nut while holding pulley the shaft won't spin if your holding onto the pulley with the key installed , when you install the pump check belt alignment and tighten if needed. .
This is the nut , Most parts stores carry them
https://www.classicchevy.com/chevy-p...E&gclsrc=aw.ds
