05-05-2021, 10:56 AM | #1 |
Front Speaker "Boxes"
I've looked around on the site and came up short finding anyone doing what I think will work best for a front audio setup. The consensus seems to be either rig up something in the factory under dash location or do kick panel speakers. I don't particularly like either of those options so I'm thinking about using something like the picture attached. It's made for a jeep but I think it will fit. So my question is, why does it appear no one else is going this route? Is there something obvious I'm missing here? Sound quality degraded? Others think it looks awful? Any opinions are appreciated.
66 Build Thread- https://67-72chevytrucks.com/vboard/...d.php?t=814582 |
05-05-2021, 12:08 PM | #2 |
Re: Front Speaker "Boxes"
My guess is probably the looks of it. You might be able to make something that tucks it up towards the middle of the firewall?
Here's what I did on my 63. https://67-72chevytrucks.com/vboard/...&postcount=314Similar to what spider did, but I don't have the space constraints that he seems to have
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 05-05-2021 at 12:30 PM. |
05-05-2021, 12:19 PM | #3 |
Active Member
I'm like you, I don't like the kick panel options or the side by side dual speakers in the original dash position.
I opted to create my own under dash speaker solution. I modified dash speaker brackets from a mid '80s square body. I located them in each corner of the dash facing down. They are only 3 inch speakers, but with larger speakers in the rear, they will be adequate. I don't need a high powered audio system. The picture shows the passenger side speaker. The driver's side is mounted in the same position. I also fabricated the grilles |
05-05-2021, 12:33 PM | #4 |
Thanks guys! I like the idea of hiding the speakers like you did Spudder. My only concern would be sound quality with how small of speaker I would be able to fit. With the after market A/C, space is limited. I doubt I'd be able to find space for 6.5" speakers. I don't mind seeing the speakers as long as it looks professional. I completely understand that looks are an opinion based thing and some may puke at the idea of mounting a speaker in sight under the dash. Again, thanks for the input fellas!
05-05-2021, 12:35 PM | #5 |
I've also seen guys add speakers and a radio to center consoles
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-05-2021, 12:36 PM | #6 |
The PO of my truck did this for front speakers. Now the speakers aren't as big as what you posted, but I am planning on putting this back in. It was in the exact location as your photo. I think it is a cool look...it is just an old acetone container. I sat it in the truck so you could see what it will look like. I think this is the only thing I will have reinstalled that the PO did...I will not have a high end system either...just 2 speakers up front and 2 in the rear cab corners...no sub, nothing fancy.
05-05-2021, 12:59 PM | #7 |
If I had known something like that existed, I would have bought one for mine, I like the look and I like my music in my face. I got a new in dash speaker and the under seat ones, will find out how I like them when I get the truck put together.
05-12-2021, 11:37 AM | #8 |
Just to close the loop here in case anyone is interested in doing the same, I've attached a couple pics. I like the way they turned out and the sound is as good as I could expect. I plan to add an amp to push them at some point as well as a sub to help with the lows. For anyone that has a stock manual floor shift truck, it may not work. I included a picture as reference to where my stock shifter hole was vs. my new shifter location.
05-12-2021, 11:47 AM | #9 |
Looks clean!
