Old 05-05-2021, 02:42 PM   #1
Desert dog
Down the rabbit hole I go. '60 Apache
While on an errand a friend and I stumbled across a 1960 Apache short bed step side sitting out in the cactus desert behind a friends house. It hadn't been moved since parked there in the early 70's. I spoke with owner who said it's mine if I can pull it out of there.
Needless to say that will be a big chore. The pack rat midden in the cab, engine compartment and underneath could be measured by the bushel. There is virtually nothing left of the tires. There is some rust in the usual places but it is complete down to the hubcaps.
We intend to bring it back to life in form or fashion but first must get it to safe harbor, and I'm sure we'll have many questions along the way.
My first one is as follows; I was hoping to grab a set of rollers off Craigslist. After some research it appears that, while readily available later 6 lug wheels wont work on the front end. Can I use wheel spacers to make the newer wheels work? And if so what size would they need to be?
Thanks in advance, wish me luck, photos to follow.
Regards.
Desert dog is offline   Reply With Quote
Old 05-05-2021, 04:45 PM   #2
MusicMan70
MusicMan70's Avatar
Re: Down the rabbit hole I go. '60 Apache
Desert dog;
I used 2" spacers in the rears and 1.5" in the front to mount the later wheels on my Suburban.
I don't recall if the spacers come with the metric lugs or not.
I did go back to steel wheels.
The spacers will work if you just want to mount them for rollers. (great idea)
Hope that helps some and subscribed for the photos, Good Luck!
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 05-05-2021, 07:46 PM   #3
AcampoDave
AcampoDave's Avatar
Wheel Vintiques makes oem style 6 lugs sold at Summit for around 80 bucks each.
AcampoDave is offline   Reply With Quote
Old 05-05-2021, 11:38 PM   #4
Desert dog
Originally Posted by MusicMan70 View Post
Desert dog;
Thanks for the reply. Would you be willing to part with the spacers?
Old 05-06-2021, 02:57 PM   #5
Desert dog
Photos loading upside down. Any help?
Old 05-06-2021, 03:42 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Explanation and info:
https://www.67-72chevytrucks.com/vbo...d.php?t=743225
Old 05-06-2021, 06:03 PM   #7
MusicMan70
MusicMan70's Avatar
PM sent Desert dog
MusicMan70
1961 GMC Suburban
Old 05-07-2021, 12:34 AM   #8
Desert dog
Here are some photos.
Old 05-07-2021, 12:55 AM   #9
MusicMan70
MusicMan70's Avatar
That first photo with the crutches laying on top is Classic and the seat...hilarious... but,
the truck looks clean and I do like the small rear window and bumper guards too.
Should clean up real nice and look forward to more photos as you go along.
Photos of hubcaps when you can too.
MusicMan70
1961 GMC Suburban
Old 05-07-2021, 02:31 PM   #10
Desert dog
It is indeed quite a site.
Sorry I didn't get photos of the hubcaps, but I did manage to get a closer look at them after hacking through the underbrush. They aren't original to the year. It appears they're off of an early 50's truck.
Old 05-07-2021, 05:27 PM   #11
MusicMan70
MusicMan70's Avatar
I am curious to see what stock wheels are on it?
MusicMan70
1961 GMC Suburban
Old 05-07-2021, 05:54 PM   #12
Desert dog
While there yesterday I popped one of the hubcaps. The wheels appear to be a matched set of the kind using three clips to retain the hubcap.
I'll be back out there tomorrow and get more photos.
Old 05-08-2021, 08:49 PM   #13
Desert dog
Here's a photo of the spare. It is the same as the ones on the truck. 15" wheel. The tire has been baked to hardness in the AZ sun for 40 years. I would bet it would hold the truck up as its as hard as a rock.
Old 05-09-2021, 01:31 AM   #14
DPowers
DPowers's Avatar
I assume you are going to trailer it out? If so why not pull it out with the tires/wheels that are on it now and then put it on jack stands, pull the 15 inch wheels off of it and then put some roller tires on those rims? Or find a set of 6 lug truck rallyes? They are usually pretty reasonable.
DPowers is online now   Reply With Quote
Old 05-09-2021, 03:48 PM   #15
Desert dog
Yes we are planning on flat towing it out. Unfortunately, dragging it out isn't an option. And we don't want to mess with the original rims right now as they will need to be cleaned up and painted prior to mounting tires.
I purchased a cheap set of 16" 6 lug wheels and tire rollers yesterday off a '99 Suburban, and have wheel spacers on the way. My concern is the size of the tires. They're 245/75 16s, about 4" larger in diameter than what's on there. Hopefully they'll clear everything enough to get the old boy home.
Old 05-12-2021, 12:49 AM   #16
Desert dog
After 4 hours of digging we got truck off its chassis yesterday and on to blocks. It wasn't pretty under there. Caked with midden and cactus.
Old 05-12-2021, 12:53 AM   #17
Desert dog
And today, for the first time in over 40 years, it was wheels down and rolling. Albeit just a foot or two.
Now on to the interior and the bushels of midden. Fun times!
Old 05-12-2021, 01:30 AM   #18
MusicMan70
MusicMan70's Avatar
Well congratulations on the extrication Desert dog!
Those wheels give it that beefy look and at least its rolling.
MusicMan70
1961 GMC Suburban
Old 05-12-2021, 09:40 AM   #19
350TacoZilla
Hell yeah man, congrats on saving an old truck that was just sitting. Funny the name Desert Dog would be a good fit for the truck considering its resting place and I use to run desert dog tires lol.
350TacoZilla is online now   Reply With Quote
Old 05-12-2021, 09:56 AM   #20
Desert dog
And believe it or not, the tires are Desert Dog tires!
Old 05-12-2021, 10:58 AM   #21
doobiebro
doobiebro's Avatar
Saweet! I can see you suiting up and spending weeks cleaning her up but well worth it!
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 05-12-2021, 11:18 AM   #22
DPowers
DPowers's Avatar
Nice
Old 05-12-2021, 08:55 PM   #23
350TacoZilla
Haha thats awesome. Do they still have the dog cartoon stamped into the sidewall? I haven't seen any in years. Either way that is a awesome coincidence.
