Old 12-22-2003, 05:02 AM   #1
Rooster's 67
Rooster's 67's Avatar
7000 rpm tach.....looks factory
Does anyone know what tach is being used to build the 7000 RPM tach dashes. It looks factory and I,ve heard that it is a camaro tach. just have to paint the pointer to match i belive. There is somebody on e-bay that is doing them, but I havent seen one in a while. I was just going to ask the guy on e-bay.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-22-2003, 05:08 AM   #2
dinnut
dinnut's Avatar
i beleive certain camaro tach's work
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-22-2003, 05:10 AM   #3
Rooster's 67
which years?
It is just a V8 tach and ill modify it but its got to be close atleast.
Old 12-22-2003, 05:11 AM   #4
dinnut
dinnut's Avatar
http://67-72chevytrucks.com/vboard/s...ht=camaro+tach
slammed 67's post
70 longbed
496/th400/Ford 9"
Old 12-22-2003, 10:38 AM   #5
smokekiki
Mike
smokekiki's Avatar
There are 2 styles of camaro tach, one is an all orange needle and one has an orange needle with a black trim ring around the center. All v-8 camaro tachs from 70-81 will work.There is a how to in the FAQ section.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 12-22-2003, 11:08 AM   #6
wlee
Just an Old Mr Goodwrench
The Ebay Dash you are talking about is built by "BOOMER85" and is a beautiful bit of craftsmanship! I had one built with an '80s quartz clock and the Camaro 7K Tach and was very pleased.
It's simple to wire & install - here's a shot of mine.
1969 CST 20 Longhorn
1970 CST 20 Fleetside
1991 Jaguar Sovereign
1992 Mazda Miata
wlee is offline   Reply With Quote
Old 12-22-2003, 11:45 AM   #7
PR454SS
PR454SS's Avatar
Damn that is nice, did it cost an arm AND a leg
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 12-22-2003, 04:06 PM   #8
71Chev
71Chev's Avatar
For those who want to do it themselves
The following instructions are from (user) Original69. from the 67-72 board.
Z28 Tach in a 67-72 truck.
Parts needed are the tach, at least 8ft wire. Crimp on ends, 6 nuts same size as the z28
guage studs, grommet, plastic cleaner, drill bit etc. I’m sure I missed something..
Here is an overveiw of the tach install. I used a tach from a 79 Z28 cluster.
1-Dissasemble the rear cover by removing the screws on the edge. I think
there are 8 of them . Set it aside.
2-Take out the black metal plate and set it aside.
3-Take the plastic plate out and you will need to remove the lines in white
that are there. I used a Meguires plastic cleaner and a whole lot of rubbing.
Be careful not to remove any of the other white lines, only the ones where
The tach is going.
4-Get the metal plate, the one with the black side and you will need to
remove the area where the tach will be. I removed just the circle area to
the edge. The tach circumference should be about ½' larger than the circle you are cutting out.
Go slow here and do a good job
5-You will have to trim off the small tab on the tach where it sticks out.
Don’t worry about the small notch that’s there, you won’t see it when
It’s done. I did cut two small pieces off of the edge for the dash lites to
Show thru at night. About ¼'
6-Put the tach where it goes. I had the bend the bottom and top edges with
small pliers before it would fit.
7-Take the tach back out and you will have to do some work to it now.
8-The tach has 3 studs coming thru an insulator plate. This will have to be
removed. I took the 3 nuts and insulator off marking on paper where
wires went. (grnd, pos, tach). You will have to screw the 2 small nuts
on the studs one at a time to DOUBLE NUT them before you cut them.
I used a cutoff wheel and cut close to the top nut. Then back one nut off
and when you do all three hook the three new wires onto the shortened studs.
9-Put the tach back into the cluster and turn it around finding the
best fit in the front. I used sheet metal screws to hold it in. You
can drill a small hole then screw the sheet metal screws in close
along side the tach. This will not show in the front and is good enough
to hold the tach from moving.
10-Now take the rear metal piece and figure out where the tach screws
could possibly hit. It is very close here. If you need room take the
plastic circuit piece off, then use a small ball peen hammer and
hit it a few times to bulge it out some. Be careful you don’t hit
it out too far as the circuit plastic might not want to go back on.
Mine is very tight but I needed the clearance inside.
11-Drill a small hole big enough for the 3 wires and a rubber grommet
to pass thru the rear plate.
12-Check everything before you screw it all back together to make sure.
I also put a few pieces of electrical tape where the studs might hit the
inside of the rear plate.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 12-22-2003, 06:26 PM   #9
Slammed67
Progress = 0%
Slammed67's Avatar
Keep in mind when positioning the tach that you don't just center it in the hole. Notice how the other gauges are lower than the centerline of the holes? This is because when you are sitting in the truck, your line of sight to the gauges is at a downward angle. If it's centered when look straight ahead at the cluster, it won't appear centered when it's in the truck. Also, if you want to be a little more "correct" about it, cut out part of the metal back plate so you can recess the tach to match the other gauges. Otherwise it'll be closer to the lens than the others. I did this to mine and it looks better and also allows more light into the tach area. However, the circuit plastic will no longer fit doing it this way. I went ahead and just rewired the whole cluster and ditched the circuit board. I was having problems with my dash lights getting good contact with the circuit board anyway. It was a pain in the a$$ (especially wiring up the lights) but it was worth it in the end.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 12-23-2003, 01:11 AM   #10
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Here is the one in my Blazer. Notice the MPH on the speedo.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 12-24-2003, 11:32 PM   #11
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
Thanks for the info/ideas. The lights on mine aren't very bright like I'd like them to be.
Since its winter now and I don't have a garage to work in this may be something I can do during the cold days. My mother and my brother have garages but I don't want to have the truck at someone elses house taking up there space and atleast its right here where I can work on it without traveling all over town to get to it. The Air Force doesn't see the logic in me bringing into the hangar to work on so it has to stay at home too.
'92 GMC Sierra, Sportside, 2wd, 350, Black
'92 Chevy Silverado Extended Cab 4 x 4, Blue
USAFR = 2A674 = Aircraft Fuel Systems Maintenance
i.e. Tank Rat
TsgtE662 is offline   Reply With Quote
