12-22-2003, 06:15 AM | #1 |
New Battery Cables time or what?!?
OK, so I go out to start my truck tonight (I haven't started it in about a week) and I turn the key and I hear "click-click-click-click". Now, it done this to me last week when I was at the gas station..and what I did was just kept turning the key from off/on really fast, and it seemed to finally light up. But tonight it was a no go. So, I turned on the headlights (pretty dim) and tried to fire it, again "clicking" sound, along with the headlights basically going OUT.
I've RECENTLY replace the Starter, Battery, AND Alternator...so now it's time for the battery cables...right? |
12-22-2003, 06:38 AM | #2 |
Available for Adoption
Well, it could be the cables or it could be one of the other things you mentioned....
Before throwing more parts at it, I would check a few things. If there are 12+ volts at the battery and it doesn't drop below 9.6v while a helper is cranking, then it's likely a poor connection. It's not un-heard-of to see a new battery drop a cell or to see the regulator or stator go out of a new altenator. Jump start it...At the battery you should get 13-15v @ 2-3k rpm, more or less=alt problems. The "click-click-click-click" is the solenoid clicking because there isn't enough juice to keep it engaged...(dim headlights) Seen lots of electrical problems posted lately and it seems that very few folks actually own or use a volt/ohm meter. These things aren't that expensive and will save you lots of time hunting and it'll also save alot of money on parts that you won't be throwing around....Another good item to have is a good 12v test light. I actually carry a test light in my glove compartment.... Never leave home without it..... Good Luck....
1983 C10 SWB 2001 Silverado SWB 1995 Corvette |
12-22-2003, 06:42 AM | #3 | |
12-22-2003, 05:12 PM | #4 |
ok, well, I charged my battery last night, and I went and it fired right up like nothin. I checked the battery terminals while the truck was running, and the battery showed it to be 13.8 at about 1500rpm, so I'm guessing maybe I just had a low battery
12-22-2003, 05:40 PM | #5 | |
#1 area for problems with current draw is the Stereo. Pull the fuse to it and see if the draw drops if your seeing excessive. Make sure the amp is shutting down with the head unit if you run seperate amps. #2 is cig plug.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
12-22-2003, 05:41 PM | #6 |
Robert Olson Transport
check the battery with a tester to see how it does under load and if ya can ( i dont care if its maintenance free) the water levels you could have a battery goin bad
12-22-2003, 06:50 PM | #7 | |
12-22-2003, 07:04 PM | #8 |
What did you do about the horn?
was the problem fixed? If you just unpluged the horns then that maybe the problem. There is a relay and it will put a draw on the battery even if the horns are unpluged if it is still stuck. Most commom horn problem is Button in steering wheel. the contact pin to let the wheel to turn wears out and then it shorts.
12-22-2003, 11:01 PM | #9 |
5-7 dropped 87 CC Dually
Grim- The contact pin is that the wire with the little spring on it? Duh (light comes on) Never mind. I didn't know that they wear out. Thanks.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
12-22-2003, 11:01 PM | #10 | |
12-22-2003, 11:19 PM | #11 |
My guess is to pull the horn button and remove the contact pin (wire). Right???
12-22-2003, 11:21 PM | #12 |
Well..there was only ONE relay under my dash, down by the fuse panel...so I took it off, and everything still works, so I guess that was my horn relay...well, hopefully it won't drain my battery anymore...none of my other cars have horns, LOL.
12-22-2003, 11:33 PM | #13 |
Under construction!
I had the same problem w/ my truck, Tim. A faulty horn relay drained two of my batteries.
2001 Silverado bagged on 22's. *Sold* |
12-22-2003, 11:41 PM | #14 | |
12-23-2003, 04:28 AM | #15 |
Here's a old tip that I am gonna pass along in spite of that avatar of yours.....LOL
Unhook the + battery cable and rig a 12v light between it and the battery. If it lights up you have draw. Pull fuses until it don't light anymore and you have found your draw. |
12-23-2003, 07:19 AM | #16 |
You get what you pay for
To make sure you have the horn relay, put the one you pulled back in and press the horn button. You should hear it clicking. Pull it back out and then try it. If no click, you have the right one.
The horn relay on my 85 is on a little panel up under the dash above the steering column. I just want to say that you guys are amazing. The amount of help in this forum is nothing short of top notch. Great work everyone.
Mike 1985 Chevy C-10 |
12-23-2003, 08:12 AM | #17 | |
