Old 05-09-2021, 08:59 PM   #1
64chevmn
Do I need lowering trailing arm cross member?
Hey guys; i tried to search and get a strong answer either way, but no luck so i'm looking for some opinions. I'm working on a 1968 C10 short box and doing a static 4/5 drop with lowering springs, drop spindles and shock relocate brackets. So, do you think i need to swap out my trailing arm cross member with a new lowering style to allow more room for the driveshaft and pinion angle? And if i don't need it for a 4/5 drop what about a 5/6 drop? I probably don't need to, but i'm also leaning towards a c-notch.
64chevmn is offline   Reply With Quote
Old 05-10-2021, 12:06 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Do I need lowering trailing arm cross member?
Not needed for a mild static drop like that.
But I do like them for the exhaust openings,... to help raise your exhaust by running it THROUGH the crossmember.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 05-10-2021, 07:40 PM   #3
PGSigns
PGSigns's Avatar
Not a real need for the cross member. Some folks will flip the brackets. You will need about a 3 degree shim for correct the pinion angle.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-10-2021, 08:29 PM   #4
64chevmn
Thanks for the response! Exhaust cut-out's was part of my plan so i'll just cut them out of the factory cross member.
Old 05-10-2021, 11:42 PM   #5
Accelo
Accelo's Avatar
I just moved them up one bolt hole and re-drilled the top set of holes.
Worked just fine.
Accelo is offline   Reply With Quote
