Old 12-22-2003, 12:27 PM   #1
CliffB
Help, Driveline or ? Vibration 71 K20
I picked up a 71 K20 with 109K original miles yesterday to replace my 72 C20. It drives beautifully. But...
There is a slight rumble on the highway that increases and decreases in amplitude over about a one to two second interval. It is the slow up and down nature of the rumble/noise that makes me ask for help. It makes me think of exhaust resonance or possible non-driveline source. I'm hearing and feeling this at an indicated 65 to 80 mph.
To me, as it isn't constant, that rules out tires/wheels and balance. Does it rule out driveline also? Prior owner did say that a tire measured out of round.
The rumble is relatively minor, but obvious to the ears and you can feel it some.
There is a really strong 1900 mile rebuilt 4 bolt 350 in it. It's a Turbo350. It has a new dual exhaust system from new jet hot coated Hooker headers back with crossover pipe and 2 chamber Flowmasters.
I'm used to 2 chamber Flowmaster sounds as I have them on my 72 C20 and 94 Roadmaster LT1 Estate Wagon.
Any thoughts? Thanks for reading. This is a great site. I'm really glad I found it.
72 C20 3/4 Custom Camper
94 Roadmaster Estate Wagon
CliffB is offline   Reply With Quote
Old 12-22-2003, 04:26 PM   #2
Stout72
Not my good side.
Stout72's Avatar
Sounds like what my truck is doing. Others on this Board recommended checking the tire balance, the u-joints or driveline angle (neither of which I haven't been able to get to yet, shame on me!)
Welcome to the site from a fellow NorCal!
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 12-22-2003, 11:50 PM   #3
CliffB
Thanks Stout72
Thanks for your reply Stout72. I talked to the previous owner today and he said not only is a tire out of round (by a lot, and therefore hard to balance) but also several wheels are out of round making balance a challenge. He and a wheel specialist did the best they could with what was on.
I'll be putting on the slotted aluminum 8 lug mags I have on my 72 C20 which I know are balanced. That will eliminate wheel/tire influence. The prior owner (good friend, racer, engineer who really knows details and has a track record of success with cars and trucks) said that the intermittent up and down rumble could also be the resonance of wheel tire balance coming in ano out of perhaps a driveshaft balance issue. If it is still going on with different balanced wheels and tires, I'll change the mounts I have for the transfer case and transmission and if it is still there, consider driveshaft balance.
It's nice to hear from another Northern Californian. If you know anyone looking, I'll be putting my 72 C20 longbed fleetside up for sale soon. It's a three owner original with 225K. Only this 71 K20 could have gotten me to part with it. I've put a lot into it.
Any other thoughts on the rumble / resonance guys?
Old 12-23-2003, 07:14 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
CliffB, It could also be a "radial" vibration as in the tires got swapped from side to side Had it happen on another truck and swapped the front tires left to right and the vibration went away. As for your resonance that would be as the vibration from the tires come in and out of phase with each other, I'm experiencing a little of that with my super swampers.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-23-2003, 04:17 PM   #5
Stout72
Not my good side.
Stout72's Avatar
I have the same mags as you do, CliffB. Just had them shod with new 35" BFG ATKO's by Costco in February. I was planning on getting them rotated anyway (nice that Costco does this for free), so thanks for the thought, JIMs, I'll do this sooner than later and see if the "thrum" goes away. Should do the free, easy stuff first anyway, right? Wouldn't hurt to have them spun as well, in case I threw a weight.
00 Suburban LT
90 Camaro RS
Old 12-23-2003, 04:32 PM   #6
CliffB
Is varying rumble common with knobby tires?
Is it common to get resonance and varying rumble or vibration with large knobby tires?
I've always used highway or all season type tread and have not had oversize tires. The 71 tires are relatively knobby in design, although not oversized.
Thanks for your post JIMs. It's interesting to know that moving from side to side can change resonance.
Thanks Stout for your last message. I'm looking forward to a major polish job on the aluminum mags. I also received 4 factory 8 lug steel wheels and trim rings (I think 73 to 80s style, grey/silver paint) with the 71 K20. I am not sure yet which wheels to sell the 72 C20 with. I hear people look for the 71 factory steel wheels that came on tthe 71. I'll bet I'll like the look of the later rims with trim rings better for a second set myself.
Merry Christmas you all.
Old 12-23-2003, 04:43 PM   #7
Stout72
Not my good side.
Stout72's Avatar
I didn't have the rumble/vibration when I had the old, worn out 35" BFG MTs on. Rode a lot rougher, too. I have only about 2500 highway miles on the ATs now, if that. Food for thought.
Mr. #1 son owes me a polish job on the mags 'cause I whupped him in a 9-hole round of golf, and he hasn't paid up yet.
Merry Christmas back atcha!
00 Suburban LT
90 Camaro RS
