Old 05-14-2021, 11:08 AM   #1
eric8
Griffin Radiator
Has anyone used a Griffin direct fit radiator for their squarebody and found it to be truly "direct fit?" Just wanting to verify before I drop $600 plus dollars. I tried to order one of Dewitts direct fit radiators for our trucks and it was too tall to fit in the stock brackets. I think there is an issue where companies have used a later model square body (mid 80's?) for their R&D and there are differences that make them incompatible with early models. Specifically in the upper mount. Seems the earlier models use a one piece top rail and later ones use two individual top mounts. I have the style below. In the pic is the Dewitt alongside the OE Harrison unit which would not fit due to the obvious height difference.
eric8 is offline   Reply With Quote
Old 05-14-2021, 10:45 PM   #2
84 400
Sb 400 club
84 400's Avatar
Re: Griffin Radiator
Looks like it was built on the big block rad specs and top plate. The bigg block top plate does not dip down like the sbc mount in the 73-80 plate. At least thats been my experience. When i swapped a diesel in my truck the diesel rad was too big and i had to use the BBC upper support.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 05-14-2021, 10:51 PM   #3
sweetk30
sweetk30's Avatar
in my opinion ZERO of these rads are direct fit as they all require custom mount options .
if they just added 4 tabs to drop in the stock mounts i would be happy .
they all need to go back to the drawing board and understand DROP IN and its definition
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-14-2021, 11:56 PM   #4
Patch
Patch's Avatar
Trying to message you 84 400.....your inbox is full
Patch
Patch is offline   Reply With Quote
