Old 05-17-2021, 12:23 AM   #1
Stephen717
Stephen717's Avatar
Harmonic balancer
So I'm working on this gen vi 454 and I need to get the harmonic balancer off to pull the timing chain cover off, got the bolt out, found out my small puller is messed up, and my large puller tried to remover the outer half of the Harmonic balancer from the inner half. So now I'm stuck trying to figure out how to remove the balancer to get the timing cover off so I can check to make sure the timing chain is alright. Then I can take off the oil pan and make sure nothing looks broken in there. So does anyone know how to pull the harmonic balancer off without it coming apart?
Stephen717 is offline   Reply With Quote
Old 05-17-2021, 12:50 AM   #2
RustyPile
RustyPile's Avatar
Re: Harmonic balancer
You need a puller that pulls from the center hub.. Harbor Freight sells one..
https://www.harborfreight.com/automo...set-62620.html
You'll need this tool to put it back on:
https://www.jegs.com/i/Comp+Cams/249...%20Categories#
RustyPile is offline   Reply With Quote
Old 05-17-2021, 01:00 AM   #3
Accelo
Accelo's Avatar
You have to be careful and only pull the balancer by the drilled and tapped holes on the hub center. Also be sure any puller you use doesn't push on the drilled and tapped hole in the end of the crankshaft. Typically there is a slug with a dimple for the puller screw to fit that goes in first. It will protect the end of the crank while you pull the balancer off. Sometimes the pointed end of the puller will be large enough not to go into the drilled and tapped hole. It still can damage the start of the crankshaft thread. I always recommend using something to protect the crankshaft. Nothing good is going to happen if you damage the threads.
Rick
Accelo is offline   Reply With Quote
Old 05-17-2021, 01:11 AM   #4
RustyPile
RustyPile's Avatar
If your wrong puller moved the outer ring on the balancer even a small amount, the balancer is ruined.. The inner hub is bonded to the outer ring by a rubber ring and if that bond gets damaged or releases, at some point (you never know when) the ring will come off when the engine is running.. Lots of carnage will be the result.. Replace that balancer...
Old 05-17-2021, 07:50 AM   #5
BigBird05
You can rent one from Auto Zone. Return it and get your money back.
BigBird05 is offline   Reply With Quote
Old 05-17-2021, 11:15 AM   #6
schovil69
A good quality balance puller/installer will thread into the crank, ensuring no damage to the threads provided the user fully installs it. Here's the style I have used for the last twenty years, https://www.ebay.com/itm/16403524292...MAAOSwffReIVn2
Only one I ever bought and glad I did.
schovil69 is offline   Reply With Quote
Old 05-21-2021, 12:28 PM   #7
Indyuke
This is the set I bought, which is surprisingly good quality. It has all the pieces for both installing and removing harmonic balancers.
https://www.harborfreight.com/harmon...-pc-63740.html
Indyuke is offline   Reply With Quote
