05-17-2021, 04:13 AM | #1 |
Do the headlight switches die?
Hi all. I'm having some trouble out of my 87's blinkers and the problem seems to be the headlight switch. I just wanted to stop by and ask if this is common. Anyone else have their headlight switch die? Or some portion of it stop functioning?
I just like to know these things for some reason. The issue was that the right blinker won't function and I've successfully traced it to the switch. Thanks! |
05-17-2021, 09:22 AM | #2 |
Post Whore
Re: Do the headlight switches die?
Well...they dont last forever...Ive changed out a couple over the yrs in different trucks
Be sure to check your plugins as well...theose can get messed up also
05-17-2021, 09:35 AM | #3 |
you sure you traced it to the headlight switch? pretty sure it doesn't connect to the blinkers.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-17-2021, 10:42 AM | #4 |
Post Whore
I was also wondering if blinkers went thru the light switch..I cant remember how the wiring goes on them
05-17-2021, 04:59 PM | #5 |
The hazards and turn signals don't go through the headlight switch.
Hazard lights go from the fuse box as a battery-hot feed, through a hazard flasher, through the turn signal switch, and out to their respective lights at each corner of the vehicle. Turn signals start at the fuse box as an ignition-switched feed, go through the turn signal flasher, through the turn signal switch, and out to the appropriate lights. Brake lights start at the fuse box as a battery-hot feed, go through the brake switch, though the turn signal flasher, and out to the rear lights.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
06-02-2021, 06:34 AM | #6 |
Well for some reason, my headlight switch is affecting the blinkers. They work fine when the headlights are off. But when you turn the headlights on, they stop working on the driver's side.
06-02-2021, 06:57 AM | #7 |
Sounds like a grounding issue in the park lights wiring. I have normally had it in the front wiring. It could also be an issue with the tail lights too. My stuff though 90% of the time for that kind of issue was broken wires or bad grouns in the front half.
06-02-2021, 09:10 AM | #8 |
I agree, it sounds like a ground issue in those front lights.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
