Old 05-17-2021, 11:27 AM   #1
pjmoreland
pjmoreland's Avatar
Fuel Line Clip Question
My '68 C10 has 5/16 hard fuel lines (307 engine). The line that runs along the frame is held with the regular clips everywhere except at the very front end up by the fuel pump. At that location there is a large slotted hole in the frame and there is a piece of sheet metal bent around the fuel line, stuffed through the hole, and bent on the outside of the frame to keep it in place. It does not appear to be an original factory clip because the ends appear to have been cut with tin snips and the cuts are crooked. What did the OEM clip look like in this location?
pjmoreland is offline   Reply With Quote
Old 05-17-2021, 04:19 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Fuel Line Clip Question
My pretty original '68 C20 w/327 engine does not have a clip in that location. Mine is metal line all the way to the fuel pump though.
LockDoc
Leon
Old 05-17-2021, 04:21 PM   #3
pjmoreland
pjmoreland's Avatar
LockDoc
Interesting. Is that a 3/8" line? My line is flared at the end like it is intended to have a soft line from there to the fuel pump.
Old 05-17-2021, 04:32 PM   #4
pjmoreland
pjmoreland's Avatar
I looked through the photos of my old '67 that also had a 5/16 fuel line (250 I6). It appears that it didn't have a clip in this location.
Old 05-17-2021, 04:37 PM   #5
LockDoc
LockDoc's Avatar
Yes, mine is 3/8".
LockDoc
Leon
Old 05-17-2021, 07:23 PM   #6
FirstOwner69
FirstOwner69's Avatar
Here's a picture taken during teardown of my fairly early '69 C/20 with 350 and and 3/8" fuel line. A rubber line runs from the curved end to the pump. I have no idea if that was a change for '69.
Jim
FirstOwner69 is offline   Reply With Quote
Old 05-17-2021, 07:29 PM   #7
pjmoreland
pjmoreland's Avatar
Originally Posted by FirstOwner69 View Post
Here's a picture taken during teardown of my fairly early '69 c/20 with 350 and and 3/8" fuel line. A rubber line runs from the curved end to the pump. I have no idea if that was a change for '69.
Thanks for posting the photo. My line stops back closer to the fuel pump, so the soft line has the 180° turn in it instead of in the hard line like yours. Having the bend in the hard line seems superior in my opinion, since it won't ever kink.
Old 08-27-2021, 06:35 PM   #8
pjmoreland
pjmoreland's Avatar
I saw this clamp on a 67 C30 in a wrecking yard today. Maybe this was for the fuel line?
Old 08-27-2021, 06:52 PM   #9
67C10Step
67C10Step's Avatar
My 67 (283 v8) had the same clip in the same location. I removed it when I ran a new hard line to the rear tank.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-27-2021, 06:53 PM   #10
pjmoreland
pjmoreland's Avatar
Was it wrapped around the fuel line?
Old 08-27-2021, 07:13 PM   #11
67C10Step
67C10Step's Avatar
Yes, and given its location it was a pain to get loose. I didn’t replace it. I ran new supply and returns to the rear tank in case I ever go fuel injection.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 08-27-2021, 07:15 PM   #12
pjmoreland
pjmoreland's Avatar
Thanks. I don't like how my fuel line is poorly supported in that location.
Going to a rear mounted tank like you did is very tempting.
Old 08-27-2021, 07:25 PM   #13
kwmech
Battery cable to starter
Old 08-27-2021, 07:32 PM   #14
FirstOwner69
On my '69, that clamp is used to retain the positive battery cable as it is routed to the starter. From there the cable passes through a couple clips attached to the oil pan bolts before getting to the starter.
Jim
Old 08-27-2021, 07:41 PM   #15
pjmoreland
pjmoreland's Avatar
Thanks!
Old 08-27-2021, 07:54 PM   #16
BigBird05
Clip on my 1970.
BigBird05 is offline   Reply With Quote
Old 08-27-2021, 07:58 PM   #17
pjmoreland
pjmoreland's Avatar
Originally Posted by BigBird05 View Post
Clip on my 1970.
Thank you. There doesn't seem to be a hole for a clip like that on my 68. I think it would be strange if GM left the fuel line unsupported.
Old 08-27-2021, 10:14 PM   #18
67C10Step
67C10Step's Avatar
Mine was a clip just like big bird and first owner posted. It was pretty much up in the frame where the front crossmember is located so it was hard to get to and pretty much impossible to put another clip in without removing the crossmember.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 08-27-2021, 10:27 PM   #19
pjmoreland
pjmoreland's Avatar
Do you remember if it secured the rubber line or the metal line?
Old 08-27-2021, 10:44 PM   #20
67C10Step
67C10Step's Avatar
Secured the metal line. It went a bit further forward along the frame and then turned just like in the photos. Maybe 6” or so of rubber line to the fuel pump.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 08-28-2021, 09:40 AM   #21
geunther
geunther's Avatar
I know mine is a different year with two extra lines, but hopefully this give you an idea potentially how the fuel line and brake lines ran.
geunther is offline   Reply With Quote
