05-18-2021, 01:57 AM | #1 |
Dropping front crossmember as one piece?
So I was going to paint the front half of the frame while I was swapping engines and was originally just going to work around the crossmember (which someone previously painted). Just looking at it now, though, is it possible to drop the crossmember with the control arms, springs, wheels and everything in place? Looks like it’s just 6 bolts holding it to the frame and then detach the shocks and brake lines? Would removing it and putting it back in even necessitate a front end alignment? Was just hoping to be able to wheel it out from underneath as one piece.
Posted via Mobile Device |
05-18-2021, 02:08 AM | #2 |
Re: Dropping front crossmember as one piece?
Yes you can unbolt it and roll it out. Shouldn’t need re aligned.
05-18-2021, 02:14 AM | #3 |
Location: Herculaneum MO (20 minutes south of St. Louis
It's a total of 10 bolts
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
05-20-2021, 11:27 AM | #4 |
I am in the middle of swapping an 84c10 front cradle into my 70c20. There are 4 bolts going through the side of the frame and 3 through the bottom on each side. Plus, you will have to pull the motor mount plates as they bridge from the cradle to the frame.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
05-24-2021, 07:20 PM | #5 |
yes it can be done
05-24-2021, 08:57 PM | #6 |
Well, its cumbersome and heavy. Items recommended but not required:
2 strong friends - One to help, one to step in when the first guy gives up. Some type of penetrating oil - the bolts are always crusty. Air or electric impact - those crusty bolts seem REALLY long after the first two or three. Beverages Last but not least - safety glasses
They tell me that I have Bipolar disorder. That doesn't really bother me. 30 minutes from now it might, but not right now. |
