05-18-2021, 03:59 AM | #1 |
tbi issue
My 89 crew cab was sitting for awhile now won't run. Fuel pump buzzes , will start by squirting gas down tbi. Will run for 15 seconds or so with both injectors flowing. Was running and starting fine last fall. Where do I start ?
05-18-2021, 06:57 PM | #2 |
Re: tbi issue
check fuel pressure. fuel pump may be gummed up from bad fuel.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-18-2021, 07:59 PM | #3 |
Re: tbi issue
Try using some Sea Foam in it and see if that helps to clean it out as well, once you get it running.
05-19-2021, 08:07 AM | #4 |
Re: tbi issue
Might be a dumb question, but are you getting oil pressure when you crank it? I think there is a safety feature that will prevent it from running if the computer is not sensing oil pressure. Just something to think about. Let us know what you find!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-19-2021, 09:57 AM | #5 |
Re: tbi issue
Here are the tbi troubleshooting flow charts from the service manual
05-19-2021, 07:39 PM | #6 |
Re: tbi issue
Thanks for posting that troubleshooting chart 44th Miss Inf, I could have made good use of these a couple of weeks ago while trying to determine if my fuel pump was bad.
06-03-2021, 02:10 AM | #7 |
Re: tbi issue
I just want to say thanks for all the help, especially the trouble shooting diagram. I had a wiring issue at the alternator! I guess if you don't give up even an old guy can win. Thanks again everyone.
