![]() Join Date: Jul 2012
Serpentine conversion
I have a 72 c10 and wanted to see if anyone has used the March Performance 20512 kit. Thanks
Re: Serpentine conversion
i bought the20450 basically the same only no air conditioning . i have it installed i love the look . have not driven it on the road yet but have moved it around the lot . seems to track real nice no squeal . i dont like that it uses the alternator as the means to tighten the belt instead of a tensioner pulley but it looks like with the air setup you got that covered
Which power steering pump and hoses did you use? I would like to be able to change my power steering pump/ which now has a remote reservoir to a pump that has a self contained one. Not sure if that’s possible or that I would have adequate clearance. I called March and Summit, they think that it would. Thanks
i used a stock pump for our trucks and bought the stainless lines from a vendor on this site parts section . plenty of clearance i will see if i can get a picture tomorrow i dont have the front clip on at the moment but it was on when i put this setup on the truck
pay no attention to the pump lines im not putting the stainless ones on till the motor is repainted and in the new frame
| Bookmarks |
