05-25-2021, 01:39 PM | #1 |
Source For 307 PCV Hose
I have been trying to locate the molded rubber hose between the intake and PCV valve. Anyone know who has them available ?
71 C-20 07 Magnum RT AWD |
05-26-2021, 11:08 AM | #2 |
Re: Source For 307 PCV Hose
Nothing ?
05-26-2021, 12:35 PM | #3 |
I just got a hose of the correct inner diameter with a 90 degree bend. I didn't care how long it was, I just cut it down to what I needed.
05-26-2021, 02:10 PM | #4 |
I can’t believe you can’t get the original style molded hose ?
05-26-2021, 02:44 PM | #5 |
i use a piece of 3/8 rubber fuel line. this is not rocket science
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
05-26-2021, 02:54 PM | #6 |
Who Changed This?
Does it look like this? I searched on a '70 402, but they are probably the same. Or, do like I did and put a 90 degree nipple in some regular fuel line.
https://www.amazon.com/ACDelco-12582...41480122&psc=1
05-26-2021, 04:02 PM | #7 |
You can see if he has more of them. http://67-72chevytrucks.com/vboard/s...d.php?t=679341
72 C10 lwb fleetside -stock 350/350 combo |
05-27-2021, 09:27 AM | #8 |
I would try a Chevelle supplier. NPD lists a pretty generic hose with a molded 90 on 1 end.
https://www.npdlink.com/product/pcv-...%3D8%26year%3D
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
05-27-2021, 07:37 PM | #9 |
I like using fuel line with a later-model-year PCV valve like GM# 6487779 that I got at the Chevrolet dealer parts dept.
05-28-2021, 10:40 AM | #10 |
Thanks that’s the ticket ! Will eliminate the molded hose completely.
05-28-2021, 05:47 PM | #11 |
I picked one up at Napa today just like the one shown above, worked perfectly...thanks for the suggestion..Jack
