Old 05-25-2021, 02:41 PM   #1
maverickmk
Quick Crossmember Question
I am rebuilding a crossmember from an '84 to bolt into my truck and was wondering if I need to get different motor perches or if they are the same as what my '69 came with. I have the stock I6 250 with 3 speed column shift.
If anyone can confirm this for me I would appreciate it.
maverickmk is offline   Reply With Quote
Old 05-27-2021, 09:19 AM   #2
mkmc69
mkmc69's Avatar
Re: Quick Crossmember Question
You should be able to use the stands that came with your '69. You may need to drill a hole through the stand into the crossmember though, if it doesn't quite line up. Just use the frame side of your existing stands as a guide/jig.
mkmc69 is offline   Reply With Quote
Old 05-28-2021, 09:28 AM   #3
maverickmk
Excellent, thank you!
