Old 05-26-2021, 11:39 AM   #1
NASTY-LSX
1985 Long bed to short bed. Whats really needed. Just brake lines?
If I convert a 85 long bed to short bed, I am thinking All I need is DS shortened and the brake line
for a short bed truck. So is it really only 2 things I need?
I know the cut measurements and everything else. Just looking for what needs to be replaced so I can order the hard parts. DS would be the last thing to get cut. Thanks
I will be doing a 1985 silverado build, and a DETAILED (because no one has done it) video on how to shorten a 73/87 C10 on my youtube channel.
From fleetside to stepper
NASTY-LSX is offline   Reply With Quote
Old 05-26-2021, 05:48 PM   #2
69Tom
Re: 1985 Long bed to short bed. Whats really needed. Just brake lines?
I asked the same question and didn't really get a response.
I was under the impression that if you had a 20 gal tank, you would also have to change it to the 16 gal tank, but don't quote me on that.
69Tom is offline   Reply With Quote
Old 05-26-2021, 07:34 PM   #3
kipps
Yes. Most long beds had 20 gallon tanks. Some of them got 16 gallon tanks instead. A 20 gallon tank will not fit in a shortbed truck.
If you have a 20 gallon tank, you'll need a 16 gallon tank to take its place. The tank brackets can be reused, but you'll likely want new mounting bolts. If you're buying a new tank, go ahead and buy a new sender unit to go with it. The fuel filler hose and/or neck needs to be changed. I don't know about the fuel lines.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 05-29-2021, 09:37 AM   #4
NASTY-LSX
Guess Ill find out when I pull the bed. I will be doing a series of videos on this.
Not one long one. Worse case, I will pick up a Tanks inc tank.
Old 05-29-2021, 04:30 PM   #5
84 400
Sb 400 club
84 400's Avatar
Brake line shortened
Tail light harness will be long
Ebrake cable?
Drive shaft shorten or from a short bed
16 gallon tank…
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 05-29-2021, 06:09 PM   #6
If your stepside doesn't have one with it, the fuel filler hose is different and hard to find. I am not sure anyone reproduces them for the stepside beds, least none that I can fine.
Old 05-30-2021, 11:22 AM   #7
dagnabbitt
dagnabbitt's Avatar
Just my recommendation, but do yourself a favour and get two 16 gal tanks, and get a switch for your dash and whatnot. Might as well, since you have access to everything. My SWB has only one tank and I can't take a relatively short roadtrip without stopping once or twice to fill.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 05-31-2021, 02:53 PM   #8
Bloodhound
Or while the bed is off convert to a rear mount 31 gallon Blazer thank and ditch the side tanks and switching.
Bloodhound is offline   Reply With Quote
Old 06-06-2021, 02:57 AM   #9
The Liberace
hatzie can help you with your parking brake cable .
The Liberace is offline   Reply With Quote
Old 06-22-2021, 10:46 PM   #10
NASTY-LSX
Yes sir, going with a https://fueltankparts.com/collection...0-in-tank-pump
Old 06-25-2021, 07:08 PM   #11
86454k30
86454k30's Avatar
Great write up.
http://www.73-87.com/7387garage/chas...lwb_to_swb.htm
86454k30 is offline   Reply With Quote
