adapting np 208 to 72 k20
any info on adapting the transfer case floor shift to a 1972 k20. it is different than the np 205 type
Thanks |
Re: adapting np 208 to 72 k20
Completely different animal if you have a 205 case is not happening...
are you saying the np208 wont work in this model pickup? I may not have described correctly. the 205 was changed out for a 208 and now I want to adapt the transfer case floor shift and linkage to work with a 208
If the 208 is already in the truck chances are the trans was swapped as well. The 208 uses a different shifter that bolts to the floor. The 205 shifter bolts to the trans to TC adapter that's most likely gone. You might be able to fab a bracket to mount the 205 shift lever.
https://www.google.com/search?q=np20...&bih=900&dpr=1 https://www.google.com/search?q=np20...tkm9vDadS913tM |
Is your truck a k vin 4wd or a later frame..post some pics..I don't think it's reasonable to utilize the 205 shifter...
